Injector Removal
Biaggio
PostPosted: Sun Oct 16, 2005 3:16 pm    Post subject: Injector Removal Reply with quote
Hi Guys,
I'm just wanting to get my injectors cleanedand need to get them out to do so. Is this something i can do myself or should i let them do it. If i do it myself is there any sort of manual to show the details of how to do it? Do they need to be specially alligned when they are reinstalled? Is there anything i should know before i even start??
Thanks in advance,
Bill, Melbourne, Australia
gritsop
PostPosted: Sun Oct 16, 2005 4:50 pm    Post subject: Reply with quote
The fuel rail is supported by 2 screws each side on the lower intake manifold. Be sure to have in hand 8 O - rounds to replace on the old ones. These are mounted on the top and bottom of each injector; the upper seals the fuel running towards the injector and the lower makes sure that the injected fiel does not escape from the lower part.
In addition have the 4 outer rubber boots replaced, they keep the dirt away. Not necessary but it is advisable.
I assume that you 're gonna have them cleaned by the supersonic method, correct?
Thanassis Gritsopoulos
