Rich B Alfa 33
Posted: Wed Dec 28, 2005 12:59 pm Post subject: 145 boxer engine - will it fit? |
Sorry if this has been covered before (I did look through the archive but couldn't find anything) - will the 145 boxer engine fit in a 33?
I'm looking for an engine but can only find one for a 145
Thanks |
Frits Alfa Arna
Joined: 27 Nov 2005 Posts: 7 Location: Delft, the Netherlands
Posted: Wed Dec 28, 2005 10:25 pm Post subject: |
The boxer engine will fit.
For the 145 and 146 a special frame was made to fit the boxer engine!
Grtz,
Frits _________________ Two type II 33 1.3s SW www.meisenbacher.nl/auto.html |
Posted: Thu Dec 29, 2005 7:27 pm Post subject: |
Issue might be getting the different ignition / injection system used to work on a 33. Not sure the 145/6 engine has the facilities for a distributor for example.
lancsbreaker Alfa Arna
Posted: Fri Dec 30, 2005 10:51 pm Post subject: |
Which 33 engine are you after - size? carb or injection?
I know I have a 1.7 16v - think I may have an 8v....
As above - 145 will fit but electrics issues...
HTH
Richard _________________ AROC Lancashire Section Secretary, and supplier of Alfabits to the gentry!
www.alfabettacars.co.uk |
Rich B Alfa 33
Posted: Fri Dec 30, 2005 11:25 pm Post subject: |
Hi lancsbreaker
I'm after a 16v motor but I need loads of other bits too as I'm coverting my 8v to a 16v.
The only problem is, I need to run it with a cat as its a 1994 car and I'm not sure if the bits from a non cat car are the same eg. wiring loom and the ecu.
If the engine you have is from a cat car, that would be great - I'll also need the front crossmember and the manifold and cat.
Anyway, let me know what you have
Rich |
Posted: Fri Dec 30, 2005 11:34 pm Post subject: |
OK - I'll check either tomorrow or on Tuesday, I know I've got a 16v and think it was from an L-reg, so should have been a cat car. I've stripped the car but should have most bits.....
Call me on 07976 384980 if you want to discuss..
Rich B Alfa 33
Posted: Sat Dec 31, 2005 7:38 am Post subject: |
Ok that sounds good - it would be great if you had all the bits. Any idea on the mileage of the car when you broke it?
Could you let me know what bits you have from my list, and then I'll give you a call
Thanks very much
Rich |
