drgoon Alfa Arna
Posted: Wed Feb 01, 2006 7:47 am Post subject: 1.5Ti go fast |
| Can anyone help me with some tips on how to make my 1.5Ti go faster. Something not to adventerous at first would be good. |
Bellamachinna Alfa 33
Posted: Wed Feb 01, 2006 3:41 pm Post subject: |
Hi...
Get the carbs, from a 1.7... Fit a K&N (or similar) air filter. I prefer those that fit inside of the original air box, because those that fit on top of the carbs get much hot air...
Thats about it... You can also improve the exhaust....
But there`s not much more, you can do, without start spending lots of money.
Keep the carbs, well tuned and balanced, use the standard Golden Lodge plugs...
Hope that helps
Posted: Wed Feb 01, 2006 6:16 pm Post subject: |
And... Lag the outlet manifold with thermal lagging.
Posted: Thu Feb 02, 2006 4:31 pm Post subject: |
And, i also forgot to mention, to polish the intakes (under the carbs)
Serpent33 Alfa Sprint
Posted: Sat Feb 04, 2006 5:02 pm Post subject: |
Agree wif the carbs. I think cheapest and easiest way to get power first is to up Venturi size to 34-36(best done in 40mm carbs) and then up the main jets to match. And also the tiny exhaust should be up'ed to 50mm after the extractors section. Of coursew if possible get the 1.7 extractors.
Err and being 1.5, Do expect low end to be affected if you are uprating the carbs. The 36 chokes work very well in my 1.7 but i don't think the 1.5 should go beyond 34. But there bound to have high end gains. My suspect is that it might bog a little.
Have fun! _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
