markgp4 Alfa Sprint
Posted: Thu Feb 09, 2006 1:29 pm Post subject: Work in progress... |
Heres a pic or two of my P4 being refurbished...
as i bought it:
home, weakcyl4, and noisey followers, so engine out:
just the first signs of rust...
Engine, suspension and s/rack and wiring all out, ready to prep and repaint:
Hope i can remember where everything goes...  _________________ make it go faster  |
Posted: Fri Feb 10, 2006 8:08 am Post subject: |
How weak was that cylinder? What were the symptoms?
(I have noisy followers and two weak cylinders in my 33..) |
markgp4 Alfa Sprint
Posted: Fri Feb 10, 2006 5:03 pm Post subject: |
hi Ben,
syptoms were uneven running, lack of engine power, just wasnt pulling well...(didnt sound right either)
so i bought a compression tester (cos just by taking off spark-leads i couldnt be sure which one was running weak) no4 cyl was 110 compared to 150psi for other three.
Strange thing is when i stripped engine down i found number 2 cyl had a bent inlet valve! so it was probably leaky h/gasket or poorly seating valves...
Have ordered new valve, new piston rings, head gasket set, and spent a few hours grinding in valves... (am waitin on parts now to rebuild it).
Mark _________________ make it go faster  |
markgp4 Alfa Sprint
Posted: Fri Mar 24, 2006 12:17 pm Post subject: Update... |
yesterday...
thats one wing painted...
and the motor cleaned up ready to rebuild...
Hoping to get it done for SAD...  _________________ make it go faster  |
johnboy 16 Valve
Posted: Fri Mar 24, 2006 12:22 pm Post subject: Re: Update... |
Mark
if you get your car done im not going,as it'l look to good
1999 freestyle superjet |
Posted: Sat Mar 25, 2006 11:32 am Post subject: |
Thanks. dont worry too much most of what ive done will be underneath...it wont even show....  |
johnboy 16 Valve
Posted: Sat Mar 25, 2006 6:45 pm Post subject: |
paulhide wrote: |
And I want to see that flux capacitor of yours anyway John.  |
Will have to take that out for the MOT, as its getting harder to get hold of the plutonium god i need a drink  _________________ WODA WE NEED? MORE POWER!!
