Posted: Thu Jun 01, 2006 2:26 pm Post subject: Starter motor problems? |
All,
My 33's starter has been playing up recently. When I first get in the car, and turn the key, the "click" noise can be heard - but the starter doesn't turn the engine
If I turn the key again - it generally starts then! Why might this be? In the past the starter has been slow to disengage - is this the cause?
Thanks!
stedee Alfa 33
Posted: Thu Jun 01, 2006 4:19 pm Post subject: |
hi
from what i remember about starters the cog of the starter moves forward to engage the flywheel, that forward movement is the problem it becomes stiff after time if you take it off and give it a clean that could sort it out
if you do want one i have got one for 15 quid plus postage
steve _________________ brum brum |
Ken McCarthy Alfa Sprint
Posted: Thu Jun 01, 2006 10:52 pm Post subject: Starter Motor Problems |
Bob
That can often indicate an electrical problem - either a poor connection or low battery. Check the terminals at the starter motor, battery and main earth to the engine. Check the battery charge and the alternator charge rate. Do your headlights dim at idle and brighten when you rev? That usually indicates low battery charge.
icky Alfasud
Joined: 20 Mar 2003 Posts: 70 Location: Lismore NSW Australia
Posted: Fri Jun 02, 2006 2:47 am Post subject: |
I've got the same problem at the moment, which is why the beast is in the driveway slowly turning "Bobber" Pink.
The starter didn't turn at all and no clicks, but this was intermittant, some days it would, some it wouldn't.
I replaced the starter motor and it turned over beautiful first time. The next day the fault came back.
Is there a relay between the key and the solenoid that could be playing up?
Dodgy contacts on the key switch?
Cheers _________________ Specialization is For Insects
1988 33 1.5 S 8V |
Posted: Fri Jun 02, 2006 8:35 am Post subject: |
Could simply be a short somewhere draining the battery? I had this problem with my white car until I sorted out the central locking system which wasn't working properly, or maybe it was just coincidence and warmer weather? You could use an ammeter from a battery terminal to one of the leads and if there was some current flowing that shouldn't be take one fuse/relay out at a time to see where the problem might be. Don't forget if you have a door open the interior lights will be using power. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Dr A. 33 1.5IE Alfa Sprint
Joined: 23 Jun 2005 Posts: 133 Location: Nicosia - Cyprus
Posted: Fri Jun 02, 2006 10:21 am Post subject: |
Hello everyone,
The clicking sound that you hear when you turn the ignition I assume that is a good sign that the ignition sends the message to the starter motor. If it doesn't you have to check the ignition.
Now if it is a problem with a stuck cog/ring from the starter that should engage when you turn the key, then what you can do is to get a can of WD40 and try to spray some lubricant inside the starter (without removing it of course). The starter motor has an opening on the side facing side/upwards underneath the intake pipe of the air filter and placed over the engine block. The starter's nose is facing towards the firewall.
Try that and it might work...
Good luck... _________________ 1994 Alfa 33 1.5 IE Cat. 220.000Kms and still going strong!!! (Από την Αθήνα και τώρα στην Λευκωσία) |
Posted: Fri Oct 20, 2006 1:30 pm Post subject: |
Hmmm.... do you mean into where I've arrowed it?
Posted: Fri Oct 20, 2006 9:13 pm Post subject: |
thats the exactly right place, Bob |
markgp4 Alfa Sprint
Posted: Fri Oct 20, 2006 9:22 pm Post subject: |
oops forgot to log in, sorry
Yes thats the exactly right place Bob _________________ make it go faster |
Posted: Sun Oct 22, 2006 12:12 pm Post subject: |
Hmmm.... out came the ECU, off came the corrogated elbow, the air filter etc... My starter looks NOTHING like the photo of the spare I have - and has no hole. Instead I've got a rubber thing!? Confused.... I'll take photos.
johnboy 16 Valve
Posted: Sun Oct 22, 2006 12:19 pm Post subject: |
Morning Rob
well as you've started stripping your engine ,you mite aswell put a proper engine in now
1999 freestyle superjet |
Posted: Sun Oct 22, 2006 2:54 pm Post subject: |
John.... coincidence you've said that as I had a good look down inside the engine bay - and it's already got one!
Posted: Mon Oct 23, 2006 2:49 pm Post subject: |
Hmmm..... It took me AGES to work out it has this cover over the cog :
Oops!
Anyway - I'm gonna change the starter for another one... There seems to be no room to remove it though. Half the problem is various pipes and wires which run over the top of the starter. Does the inlet manifold need to come off to change it then? Or do I just have rubbish routing of these tubes and cables? I'll have to take the manifold off in this case anyway - and reroute everything properly.
For example, the coolant junction is sitting on top of the starter, as is the AAV pipe and the clutch hydraulic piping.
Surely this all needs to be routed somewhere else?
Thanks!
johnboy 16 Valve
Posted: Mon Oct 23, 2006 3:15 pm Post subject: |
Hi Rob
Yes you do have to take off the inlet manifold.well i had to on my 16v,so i would think you would for yours?
Tim Alfasud
Joined: 14 May 2005 Posts: 29 Location: The Netherlands
Posted: Mon Oct 23, 2006 4:25 pm Post subject: |
Before you pull out the motor (if you haven't already) try getting a piece of fairly thick cable and attaching one end to the +ve pole of the battery then dabbing the other end directly on the starter motor terminal.
I had the same problem as you and changed out the starter motor only to find it was a high resistance connection somewhere in the starter circuit (probably in the pain-in-the-a*se immobiliser I have fitted). I rigged up my own starter circuit utilising one of the unused switches on the dashboard and a relay and it's worked perfectly since then! _________________ If it 'aint broke.........it needs some more fixing! |
Scott Sander Alfa 33
Posted: Mon Oct 23, 2006 9:50 pm Post subject: |
Tim wrote: |
I had the same problem as you and changed out the starter motor only to find it was a high resistance connection somewhere in the starter circuit (probably in the pain-in-the-a*se immobiliser I have fitted). I rigged up my own starter circuit utilising one of the unused switches on the dashboard and a relay and it's worked perfectly since then! |
Yeah had a similar problem 6 years ago, except connected the relay up to the existing starter motor solenoid control wire. It works because the new relay uses far less current than the starter solenoid.
Have a look at my website for the relay mod details. This type of mod can also be used for headlights, etc _________________ Scott Sander
http://www.sanderfamily.com |
Posted: Sat Oct 28, 2006 7:07 pm Post subject: |
I replaced the starter motor - that was clearly the problem. It starts first time again now.
Thanks people for all the advise - and thanks Paul for the starter motor.
