duncan_156 Alfa Arna
![](images/avatars/319964085445aa6ff8c5da.jpg)
Joined: 05 May 2006 Posts: 3 Location: Brisbane, Australia
Posted: Fri Jun 09, 2006 2:54 am Post subject: Alfa 33 8v 1.7 ie 1989 - Air Conditioning Clutch switch ? |
I have just overhauled my 8 valve engine. The car has air conditioning fitted - perhaps by the factory. On the firewall between the oil filler pipe and the distributor, there is a vacuum actuator for the electrically operated air con compressor clutch.
The vacuum actuator gas two vac pipe attachments on the end of the actuator - 1 from the manifold (shared with the fuel pressure regulator), the other is my problem - what does it attach to? At the moment I have it pinched off and everything is working OK.
Must pay more attention when disassembling things!
Any help much appreciated.
Duncan |
Posted: Sat Aug 12, 2006 4:25 am Post subject: |
How do I set an avatar on this board? |
Scott Sander Alfa 33
![](images/avatars/88734733242d8a855752f0.jpg)
Posted: Sat Aug 12, 2006 5:59 am Post subject: Avatar |
Anonymous wrote: |
Guest,
You need to register to create a profile, then you can set an avatar for the profile. This is just one of the many benifits in registering. _________________ Scott Sander
http://www.sanderfamily.com |
