Yvon Alfasud
Joined: 22 Apr 2003 Posts: 31 Location: Wavre, Belgium
Posted: Thu May 22, 2003 5:57 am Post subject: Engine swap and runing problems (5 questions !!) |
First, thanks for all your advise. This week-end I swap the two engine on my 33 16V.
Status now : camfollower noise is OK ... no more clicking . However, engine doesn't have any power, is back firing, loud is like a Citroen 2CV and some pufff in admission.
I proceed to the camshaft belt replacement and respect all pointers and rechecked several time. However I'm still convinced they are not correct.
Q1 : when you place the belt with 2 pointers on upper pulley and the pointer on lower pulley in between upper pointers, lower pulley(exhaust) seems to start compress but doesn't look to be at 12 o'clock. So I force it to be on 12 o'clock. Am I wrong. Upper pulley, go wrong as soon I release the belt. So I also place it at 6 o'clok by adjusting the pulley (this looks correct to me)
Q2 : when I proceed to the test with small triangle, is there any way to know for sure belt are correctly placed. It looks to me, you can easly be wrong by one tooth. When one side has the triangle correct, the other side is in the opposite side. Is this correct ?
Q3 : I would like to check if sparkplug are working but see a lot of time ... do not disconnect the plug. So how to check ?
Q4 : May I disconnect injectors leaving it on the rail. Cranking a few time and see a spray? How this should happens : all 4 together ?
Q5 : May I electrically disconnect the injectors one at a time when engine is running and check for variations ?
Sorry for all those questions that maybe already appear in this forum but I'm quit lost after working 16 hours to swap engine and another 16 hours to fix this b..... problem that eat my brain.
Please, if you have any and Thanks in advance for any response,
Yvon Duvivier |
Yvon Alfasud
Posted: Tue Jun 03, 2003 11:05 am Post subject: |
Made some progress on this subject.
Q1 : when marks are aligned, turn WITHOUT releasing tensioner until triangles are aligned. Then release tensioner on that side. Continue to turn until triangles from other side are aligned and release tensioner form that side. When both belts are in tension, check again the marks. I my case I should start a bit misaligned to get correct alignment when belts are released.
Q2 : Yes, a V should appear on the flywheel. BUT DO NOT CHANGE if they are not perfectly aligned. This position for camshaft is just to be sure none of the valves are pushing on the camshaft. They do NOT have to be aligned.
Q3 : not yet checked
Q4 : not yet checked
Q5 : YES, unclips before starting the engine. Start it and disconnect one at a time. You should clearly see the difference and engine can even stop.
In my case, cylinder 1 and 2 are working BUT not 3 & 4 !!!!
I change fuel rail and recover about 75% power but still looking for the 25% missing.
Do you know any reason why cylinder 3 & 4 are not working (no RPM diff when I disconnect the injectors)
Ciao
Yvon |
Marcin Alfa Sprint
Posted: Tue Jun 03, 2003 11:38 am Post subject: |
Q3: Remove the plug from the engine, connect the connector and touch a metal part of the engine with the spark plug's thread. Let someone crank the engine, you should now see the spark. Done it many times, no probs. Personnaly I would then also disconnect the the injector in order not to let unburned fuel get to the cat. One more thing: I avoid holding the connected plug with bare hands - nothing should happen, but once I tried to disconnect the plug when the engine was running and got a nice electric shock
May sound obvious but the reason for not working cilinders is that wheter there is no spark, or no air-fuel mixture.
Good luck
Marcin |
Matt C Alfasud
Joined: 13 Mar 2003 Posts: 43 Location: Brisbane, Australia
Posted: Tue Jun 03, 2003 2:14 pm Post subject: |
Take special care when connecting and disconnecting components on your engine wiring harness, such as injectors as you may ZAP your ECU
 _________________ Molto Veloce! |
Posted: Tue Jun 03, 2003 4:40 pm Post subject: |
That's what worring me !! Even if I have a spare ECU I don't want to burn it. Probably will apply a strobe with induction clip.
I'll continue in my "power" research !!
However, thanks for your answers
Ciao,
Yvon |
