Sud1983 Alfasud
Posted: Mon Dec 04, 2006 4:01 pm Post subject: 33 16v Timing |
Can anyone tell me what the timing is on a 33 16v?
Jaty. |
Scott Sander Alfa 33
Posted: Mon Dec 04, 2006 8:40 pm Post subject: |
Does this help?
http://www.alfa-pages.co.uk/viewtopic.php?t=2905
or firing order 1 - 3 - 2 - 4
The timing is controlled by the ECU, it gets a signal of the crank angle by a sensor next to the fly wheel at the back of the motor on the LHS. _________________ Scott Sander
http://www.sanderfamily.com |
Sud1983 Alfasud
Posted: Mon Dec 04, 2006 11:35 pm Post subject: |
No sorry I didn't mean the cam timing but the distributor timing. I've dropped a 16v lump in my Sud and am running it on carbs, so when I get it finished and fire it up, and so would just like to know the 33 16v dizzy timing so I can get a base to start from.
Jaty. |
tinworm Alfasud
Posted: Tue Dec 05, 2006 3:46 am Post subject: |
A bloke showed me once and for all (after worrying him to death repeatedly) how to time an engine roughly. What you do if you can is have number one on t.d.c. on the compression stroke, if you can't see what is happening have a look at number four which should have both cams rocking. Try to have the cams equally open/closed on four and both valves closed on one which corresponds to t.d.c. on number one. Works on all engines that I've come across and is easy if you can't work out the timing marks on the cams/ distributor etc.
See how you go with that, sounds strange but is easy if you're actually doing it hands on.
Cheers,... Col. _________________ 1977 Alfasud ti 1.7
1985 Alfa 33 4x4 1.7
1968 1750 GTV
1986 Alfa Sprint 1.5 QV |
