Serpent33 Alfa Sprint
Posted: Thu Jan 25, 2007 11:20 am Post subject: Cam hardness after reprofile |
Was wondering any of you have experience that may share. If the lobe at 0 lift is grinded off, will the cams face any problems? Since the grinded off part is where there is tappet clearance and the chrome hardened part when lift occurs is intact.
Thanks for any imputs. _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
hugh jinjin Alfasud
Posted: Mon Jan 29, 2007 5:47 pm Post subject: |
hi, any cam company will re-harden a reprofiled cam if thats what your worried about.
there are however issues with reprofiled cams for boxers.
Adie Hawkins(ahmotorsports) who has probably seen more tuned boxers than all the members of this forum put together says that in the 8v engine they cause premature wear of the cam carrier.
In 16v engines the lobe base circle diameter is only 1mm bigger than the bearing journal so there isn't enough material to remove without the cam follower hitting the bearing journal.
there are companys who will weld the original cast iron cams and then grind them but the cost for this usually is not much different to the cost of new steel cams. |
Posted: Wed Jan 31, 2007 12:56 pm Post subject: |
Thanks a lot for the reply. There goes my budget modification. _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
