Series 1 1.5 Single Carb - Duel carb
Shaun
PostPosted: Tue Jun 17, 2003 10:24 am    Post subject: Series 1 1.5 Single Carb - Duel carb Reply with quote
What is needed to upgrade a 1.5 single carb to a duel carb format.
Do you have to replace the head's? If not what happens to the water chanel which runs in the inlet manifold?
Matthew Kirkcaldie
PostPosted: Wed Jun 18, 2003 1:28 am    Post subject: Replace the heads Reply with quote
I had a single carb engine transplanted from a rusted out Sprint into my 33. I hated the single carb performance and so I asked my mechanic to put our existing twin carb setup onto the engine. The inlet ports are different, so sure enough it required a head transplant. That worked with a standard gasket kit and took a bit of fiddle, but everything has worked well for six months now, and the performance is vastly improved from the single carb.
Dick
PostPosted: Wed Jun 18, 2003 3:32 pm    Post subject: I can help/... Reply with quote
Hi.. If your in Oz ..... I can source for you an inlet manifold especialy for the purpose single to twin carbi conversion... It fits the single carbi head.... and has better flow than the tstandard twin manifold.
Is a new item.... if you are interested let me know and ill find a price...
RIch
Shaun
PostPosted: Fri Jun 20, 2003 11:52 am    Post subject: I'm in South Africa Reply with quote
Sorry Dick but I'm in South Africa.
Now your got me interested, who built the minifold, do you have the plans?
Is there any way I can still get it from you?
And finally what's the price?
Thanx.
