				 Posted: Mon Jun 30, 2003 11:29 am    Post subject: noisy fuel pump |
				hi!
my fuel pump (33 1.3ie) is getting noisy ; as soon as the tank gets a little low on fuel, a continuous whine occurs. the electric pump has been replaced not very long ago by another one bought from alfa romeo.
i suspect a problem coming from a fuel pipe in the tank : clogged sock filter, air duct? ; i want to correct it since topping up the fuel level every 100kms isn't very fun.
but i didn't find any "hole" in the trunk to have access to the tank ; do i have to drain the fuel, and drop the tank to get access to the fuel sender and pipes?
thanks for any advice
regards
		Ketil-no Alfa Arna
  Joined: 08 May 2003 Posts: 20 Location: Bergen-Norway
				 Posted: Mon Jun 30, 2003 12:28 pm    Post subject:  |
				You have to take down the fuel tank to get access. The pump suck petrol from the top of the tank.
To get the fuel out of the tank you have to take of the big rubber bend on the left side of thank (fuel inlet). It's easy to do if you have no petrol in the tank...
A little history:
I had to take down the rear suspension unit on a Merc 190E I once had. And to take that down I had to loose a 1/2 inch feed pipe to the petrolpump (from the tank in the boot). The tank was half full. I didn't think. I got petrol all over me (even inside my ear). My garage was filled. I had a 150W lamp glowing beside me...
I know I am lucky to be alive....
It's fun to work with petrol!
Ketil[/b] |
				 Posted: Tue Jul 01, 2003 6:32 am    Post subject:  |
				Maybe you don't have to drop the tank, which is a horrible job!
On the series 1 Alfa 33 with mechanical fuel pump, you can agin access to the fuel supply line and the fuel level sensor by taking out the bottom cushion of the rear seat.  Under the seat you may see a circular outline under the sound proofing bitumen felt - just cut around the circle , peel away the felt and you should be able to remove a couple of screws holding down the access cover.  It's a lot less messy than removing the tank.
Rob (Perth) |
