baldy Alfasud
Posted: Wed Jul 04, 2007 8:44 pm Post subject: 145 gearbox |
Hi ,does anybody know if the alfa 145 1.7 gearbox will fit a 33 once the gear selector rod and speedo hub are changed over ? as they look nearly identicle. cheers Lee |
Toad Alfasud
Posted: Mon Aug 20, 2007 4:11 pm Post subject: |
Yes they will, I ran a 145 box in my sprint for a while. No speedo and I made up a new linkage to suit, shift was worse than standard, so not an ideal solution. But had I bothered to refine the system it might have been alright.
I was going to try using a cable setup, but things happend and plans changed. _________________ Shift for Brains |
baldy Alfasud
Posted: Tue Aug 21, 2007 9:23 am Post subject: 145 gearbox |
HI, Did you have any clearance problems in the tunnel ie banging?cheers lee |
Toad Alfasud
Posted: Fri Aug 24, 2007 9:40 am Post subject: |
Difficult to say, it's a race prepared car so the noise levels while driving with a helmet on are fairly high.
I don't remember seeing any knock mark on the underside or box when I took it out. Although I do have a differnet top engine mount, which may leave the engine and box hanging a I little lower than standard. _________________ Shift for Brains |
