16v campervan Alfa Arna
Joined: 13 Apr 2007 Posts: 11 Location: Crowborough, East Sussex
Posted: Fri Jul 13, 2007 10:33 pm Post subject: 16v ignition timing. |
Hi folks, does anyone know the ignition timing for the 16v, ie how many degrees BTDC the engine fires. Because of the way I have mated the Alfa engine with the VW gearbox I had to move the timing gear and mount the sensor in the bell housing. I have a small amount of adjustment in the sensor and now want to get it accurate with a timing light. Also does anyone know the correct psi for a compression test. Cheers, Tony. |
stedee Alfa 33
Posted: Sat Jul 14, 2007 12:59 am Post subject: |
have you used the brain from the alfa if so you cannot adjust the timing the brain automatically compensates however much you move the dizzie _________________ brum brum |
Posted: Sat Jul 14, 2007 8:53 am Post subject: 16v timing |
Hi, thanks for the reply. I realize the distributor has no effect on the timing. Its the crankshaft sensor that i am trying to adjust. You wouldn't normally have to do this. But my set up is obviously not standard. |
Posted: Sat Jul 14, 2007 8:18 pm Post subject: |
Not sure on the exact psi for a compression test but i believe it should be around the 160 mark |
