Rosco Alfasud
Joined: 17 Apr 2003 Posts: 27 Location: Rotorua New Zealand
Posted: Sun Nov 18, 2007 10:43 pm Post subject: Rear Suspension trailing/leading arm bushes.. |
Hi guys is there any easy way of getting these bushes out, and does the trailing and leading arms have to be removed to do it as I have to replace the bushes both sides where they attach to the subframe.
Would it pay to jack the rear up and place axle stands under the rear axle prior to proceeding with any removal of bolts etc..
There also appears to be round rubber washers either side of each bush, which in my case appear to be disintergrating.. Are original bushes to insert in the rods still available.. if so any suggestions of who to get hold of..?? websitwe/email address |
