Errol Alfa Sprint
Joined: 20 Mar 2003 Posts: 114 Location: Sydney, Australia
Posted: Sat Jul 19, 2003 9:18 am Post subject: Tighten clucth? |
My clutch pedal has about 3-4cm of play in it, and im wondering if i can tighten it from the pedal, not the actual main clutch set up. Because i cant get into that stuff, only simple things for me!  _________________ 91 Alfa Romeo 33 16v * SOLD*
Lowered 45mm
15 x 7 inch advanti wheels
Falken 195 low profile
K&N Pod filter
Cannon 2inch exhaust from cat-back with 3inch tip. |
Jas Alfasud
Posted: Tue Jul 22, 2003 12:59 pm Post subject: clutch |
the clutch is hydraulic, you can't adjust it as such. If it's just play, then have a fiddle with the pedal. Otherwise it's worn. any slipping? |
Toad Alfasud
Posted: Fri Jul 25, 2003 10:03 pm Post subject: |
try bleeding the slave cylinder
and check for any leaks, even very small one's _________________ Shift for Brains |
Luciano Alfa Arna
Joined: 13 Mar 2003 Posts: 22 Location: Buenos Aires, Argentina
Posted: Sat Jul 26, 2003 11:49 pm Post subject: |
Your problem is the pin that conects the pedal. You have to change it. It´s atached by a zeger nut.
I have the same problem now. If you dont change it one day it will break and you'll can't change gears.
I´ve done a Autocad drawing of it, to do a new pin, tell me if you want it.
Cheers _________________ Alfa Romeo Trentatrč Q4 '94 |
Errol Alfa Sprint
Posted: Sun Jul 27, 2003 12:59 am Post subject: |
Yes that would be very helpful! Thanks! _________________ 91 Alfa Romeo 33 16v * SOLD*
Lowered 45mm
K&N Pod filter
