Posted: Tue Aug 05, 2008 2:54 pm Post subject: emissions |
I drove my car to my mates work place, car was nearly empty of petrol, he works as a mechanic for a truck and lorry place.
We did brake test and then emissions test, it passed on tick over but failed on fast idle, so drove home to get my bits and filled up on same shell optimax fuel and came back. I did my brakes and then changed my ECU chip for the standard one and cleaned the lambda probe and let the car heat up. We then re did the emission test and it passed on idle and failed again on fast idle but this time it was worse??
Anyone know why??? _________________ x2 33 16v
Posted: Tue Aug 05, 2008 5:55 pm Post subject: |
Hi Al,
I'd be tempted to try a brand new Bosch lambda.
Posted: Wed Aug 06, 2008 2:04 am Post subject: |
Lambda sensor was new last mot and car has not done many miles, I hope it’s not that as they are v expensive.
Today when I started the car from cold, it started ok but didn’t like to rev and smells like it’s over fuelling.
I removed the lambda out of the equation by telling ecu there is no lambda and disconnecting it and it still did the same. The lambda is working on idle when warm, you can hear it changing the fuel mixture as per normal.
I will try with up rated chip and or another ecu I think. _________________ x2 33 16v
Posted: Thu Aug 07, 2008 2:20 am Post subject: |
I undid the 5 min AFM mod today, I will see in the morning, with a cold start, if its made any difference and then possibly try another emission test with a few different ecu's if not. _________________ x2 33 16v
Posted: Fri Aug 08, 2008 4:41 pm Post subject: |
Last night we tried again with another standard ecu and still got 0.59 - 0.61 ish on fast idle at 4k afer a drive. Boy did i not like holding 4k and stopped when temp gauge got to 100 ish, even though the warning light didnt come on.
I started it this morning from cold, with a different standard ecu and it didnt fast idle. I put in another chipped ecu and it idled fine and fast idled and drove ok??? I cant remember which one now, as i have a few to play with.
I'm thinking that the normal ecu gets its engine temp from the coolant temp sensor "CTS" and the chipped ECU gets it from somewhere else. Could the chip just tell the ECU that the engine is colder than it actually is, therfore putting more fuel in, along with a slightly different map?
Does anyone know what the resistance should be at cold and at normal running temps, the motronics data sheet only talks about a 5v referance value and mentions no range form cold to normal running temp. I was thinking of putting in a resistor for the time being as its using loads of fuel now.
I tested the CTS with a voltimeter on resistance and got no reading when at normal running temp or when cold and there was no short, so i think its dead. _________________ x2 33 16v
Posted: Fri Aug 08, 2008 5:47 pm Post subject: |
I would very much doubt that the chip does anything like take a different source for the engine temp. Should just be a different map.
Posted: Fri Aug 08, 2008 6:36 pm Post subject: |
Just a coincidence that the sensor went at the same time I swapped the chip, i hate things like that, hard to diagnose. Or maybe the CTS went ages ago and the chip i have was sooo good it didnt need it and when i put it back to standard it highlighted the problem I assume that a failed sensor is seen as no signal and equates to an engine always cold state? _________________ x2 33 16v
Posted: Fri Aug 08, 2008 10:20 pm Post subject: |
Possibly, or possibly it just defaults to a guessed temperature.
Posted: Sat Aug 09, 2008 1:51 pm Post subject: |
What I can’t figure out is that when the engine IS cold it runs bad on fast idle with standard chip but not another? If a CTS fail is guessed temp you would think that guessed temp would be close to a cold temp or car wouldn’t start. Mine starts fine and idles "I always start with no throttle as you should" but anything other that closed throttle position, it stutters. _________________ x2 33 16v
Posted: Mon Aug 11, 2008 7:48 pm Post subject: |
I wish someone answered this before I bought a new sensor
| Quote: |
| Does anyone know what the resistance should be at cold and at normal running temps, the Motronics data sheet only talks about a 5v reference value and mentions no range form cold to normal running temp. |
I found out the hard way, I tested the new sensor and thought it was faulty, for future reference guys you need to use the 20k range on the multimeter and you should get the following.
| Code: |
cold hot
2.6ish .28ish New sensor held in header tank
2.6 .23 Old sensor in engine
Dont have access to a thermometer  _________________ x2 33 16v
Posted: Mon Aug 11, 2008 8:16 pm Post subject: |
Need help understanding the 5 min AFM mod.
The engine at a set rpm will draw in required amount of air (a)
The flap is set at a set resistance (r)
If you alter (r) to be lower, the same amount of air is going in, albeit at a slower rate, as the engine only sucks in what it wants but the flap position opens further, telling the ecu that more air is going in and so puts more fuel in.
I would assume this is true for the opposite, as in if (r) is increased then the same amount of air is being sucked in but at a higher rate as the flap position is restricted, telling the ecu that less air is going in so decreases the fuel.
How come when I had a play around with my flap, trying to put it back to original, I realised that I had increased (r) and definitely got better torque, ect ect?
The person who marked the toothed wheel prior to me owning the car had indeed loosened it, if he used the reference point of where the w clip holds the tooth in place. I put it back to normal reference point but it got better the more I tightened it??
HELP!!! _________________ x2 33 16v
Posted: Tue Aug 12, 2008 10:23 am Post subject: |
I would guess that for some other reason the engine is running too rich, and adjusting the afm is just reducing that richness.
Posted: Wed Aug 13, 2008 12:43 pm Post subject: |
Just had a thought, if the CTS had failed the car wouldn’t start. I tried with it removed and it didn't. One of the terminals had a bit of corrosion on it though and when the car is running whilst warming up if you remove it there is a definite change in engine tone, but no change when hot??? _________________ x2 33 16v
Posted: Wed Aug 27, 2008 4:13 pm Post subject: |
I changed the AFM for a non opened one and didnt tune it for idle " remove cat and adjust idle mixture screw" and on fast idle at 2k - 3k the emissions were .23 - .30. So it should pass if i put a bottle of injector cleaner in it and set the idle properly as its a bit rich.
The manual says if changing an ECU or AFM then you need to set idle with lambda disconnected, i guess it needs a good reference point. _________________ x2 33 16v
Posted: Thu Sep 04, 2008 1:08 am Post subject: |
well i tried with an unopened AFM, everything but the CO is good, so lambda is working, cat is working, its just over fueling!! Arghhh!!
mechanic says changing the cat wont help as its doing its job, lambda is working and high fuel pressure shouldnt make that much of a difference.
I have set the timing "dizzy cap" to standard, made no difference, tried virgin AFM, slight difference, cleaned the lambda sensor, how else can i get over fueling down?? _________________ x2 33 16v
Posted: Thu Sep 04, 2008 12:12 pm Post subject: |
better fuel grade is supposed to give a cleaner burn, plugs are the correct platinum for cat 33 and looked fine when head was off. _________________ x2 33 16v
Posted: Fri Sep 05, 2008 1:08 pm Post subject: |
Check carefully for any air leaks in the exhaust. Air getting in there can register as a weak mixture via the lambda probe, hence triggering the ECU to richen the mixture.
Posted: Fri Sep 05, 2008 2:40 pm Post subject: |
Al,
has your car got standard injectors?
Just a thought that some previous owner might have put in bigger (vauxhall carlton??) injectors to try and get more power.
Think the bigger ones are brown. Standard are yellow.
Posted: Fri Sep 05, 2008 4:52 pm Post subject: |
Mine are standard yellow ones. It must be, bad map, high fuel pressure, leaking injector or Lambda sensor.
I will try with another ECU when i get a chance, then get injectors checked and at a last resort get a lambda sensor, unless anyone else can think of anything. _________________ x2 33 16v
Posted: Sat Sep 06, 2008 1:01 am Post subject: |
hi, do you get some blink codes from ECU? if no i'd replace lambda sensor as a likely culprit with OEM unit.
Posted: Sat Sep 06, 2008 1:05 pm Post subject: |
I should be getting it on an alfa diagnostics on Tuesday to check everything. Can you diagnose a sticky injector by removing HT lead and injector wires for each cylinder 1 at a time and run emission test? _________________ x2 33 16v
Posted: Wed Sep 10, 2008 11:45 am Post subject: |
well i took it back to the alfa garrage but he didnt want to put it on the diagnostics saying that you cant see the advance readout! I have seen this last time i had it on one of those things and it also showed the lambda readout. I guess i will have to make up some kind of connection and connect it to the lambda connection to get a read out but whilst on the emission tester it said it was ok, not sure how good they are??
I havent replaced the lambda sensor as they are pritty expensive, i will do as a last resort, but even when it was new i still had problems.
Disconnecting the fuel relay type device, so it thinks its running on 97 ron fuel "which it is" does make a difference, the timing is advanced and it does accelerate harder.
I was thinking of changing the coil??? _________________ x2 33 16v
Posted: Wed Sep 17, 2008 1:56 pm Post subject: |
does anyone else have problems with emissions on the 16v's? my first red 16v would fail on fast idle but it was allowed a faster idle and it passed. I have always had problems with my silver one. _________________ x2 33 16v
