16V tensioners and idlers
andrew
PostPosted: Wed Aug 13, 2003 3:50 am    Post subject: 16V tensioners and idlers Reply with quote
Can someone tell me if there is a difference between the idler and tensioner? From what I can tell they look exactly the same although I remember reading somewhere that they are different. Any help appreciated.
graemeroberts
PostPosted: Wed Aug 13, 2003 3:08 pm    Post subject: Pulleys Reply with quote
They're the same.
Part no. 60504226, £12.74 each.
Idlers bolt on, tensioners pressed on with a steel pin which is a pain.
andrew
PostPosted: Fri Aug 15, 2003 4:30 am    Post subject: Reply with quote
Thanks. What made me wonder more was that I received two in older packaging and two in newer packaging. Now to pressing these tensioners on, thanks again Very Happy
