fuel smell
PostPosted: Sun Sep 12, 2010 12:24 pm    Post subject: fuel smell Reply with quote
Hi guys,
I went all the way around a roundabout the other day fairly quick and could smell fuel.
The tank was nearly full, could I have a filler neck leak or petrol cap leak, how do I go about testing for this.
One thing I have noticed for a long time is that I no longer get the hissing sound when I take the fuel cap off to fill up, the locking mech for the fuel filler cap is also stuck but twists on and off ok.
Alan
PostPosted: Sun Sep 12, 2010 12:30 pm    Post subject: Reply with quote
Chuck it 'round the roundabout again and if the fuel has gone down the outside of the wing it's the cap, else if on the tyre, probably the rubber concertina between the plastic filler mouth and downpipe.
I'm guessing if you no longer get the 'whoosh' there is an air leak somewhere, most probably one of the above, or the rubber tube from the plastic downpipe to the tank could be perished, but i think this would then leak all the time.
PostPosted: Sun Sep 12, 2010 12:56 pm    Post subject: Reply with quote
ok Smile
Any excuse to chuck it round a roundabout is welcome Smile I will do it next time I fill up
When I fill up, I always fill up to the brim and haven't seen any leaks yet Smile
Alan
JeremyC
PostPosted: Sun Sep 12, 2010 10:12 pm    Post subject: Reply with quote
Partial hijack, I always get blowback ( Shocked ) when I fill up, where is the tank vent?
'93 Black 33 1.7 16v
PostPosted: Sun Sep 12, 2010 10:30 pm    Post subject: Reply with quote
JC, that is normal and you should get that, as far as I know, I am not getting it.
I assume that air is allowed to be sucked into the tank as it empties, otherwise it would implode?
Am I missing anything?
JeremyC
PostPosted: Mon Sep 13, 2010 8:45 am    Post subject: Reply with quote
When I fill an almost empty tank I have to go really slowly for the first five to ten litres or the fuel just blows back out.
The tank is of course full of fuel vapour which, I guess, is less mobile than air and therefore is reluctant to get out of the way for the incoming fuel. It was my understaning the most cars had a vent to allow it to escape.
Interesting our old 33 used to do this too (just one of many 'ahhh, yes, I remember" moments when we got this one).
Surely they didn't do this from new.
PostPosted: Mon Sep 13, 2010 9:08 am    Post subject: Reply with quote
I have only had problems with late 16v cars. All others fill fine. (The wonders of progress again.)
JeremyC
PostPosted: Mon Sep 13, 2010 9:23 am    Post subject: Reply with quote
Our previous car was a late car, 'J' but only a 1.5ie.
PostPosted: Mon Sep 13, 2010 10:40 am    Post subject: Reply with quote
Lol
JC that sounds bad, I remember that in my 2nd ser3, was very annoying, I thought it was the pumps and used to change the angle of the handle of the pump, used to mainly do it at BP, I now only use shell fuel and don't often get it.
The fuel vapours are supposed to go from the tank to a carbon canister under the front left wing and then into the intake via the 6 legged plastic spider thingy.
Can you get your car on scantools diagnostics and do a purge to check it is working.
Mine wasn't working as the wires were corroded, after fitting new connections it purged.
JeremyC
PostPosted: Mon Sep 13, 2010 10:55 am    Post subject: Reply with quote
Is that what the thickish white pipe in the rear to front bundle is?
PostPosted: Wed Sep 15, 2010 10:02 pm    Post subject: Reply with quote
With the leak, my old Sportwagon leaked from the seam I think, and then from the seal around the fuel gauge sender unit. Neither expensive to fit, just horrible jobs where you are bound to get covered in petrol.
Think it runs up parallel with the filler pipe. My old Sprint used to do it as well, but none of my 33s have.
JeremyC
PostPosted: Wed Sep 15, 2010 10:49 pm    Post subject: Reply with quote
Hmm, need to go poking around with a bit of wire methinks.
PostPosted: Sun Sep 26, 2010 7:42 pm    Post subject: Reply with quote
The fuel all down the side of the car was a good give away lol, I just filled up and noticed that the rubber ring in the fuel cap is missing.
Anyone got one spare??
PostPosted: Sat Oct 16, 2010 8:17 pm    Post subject: Reply with quote
Anyone got a spare fuel cap rubber??
PostPosted: Sat Oct 16, 2010 10:40 pm    Post subject: Reply with quote
Where is the fuel cap rubber?
PostPosted: Sat Oct 16, 2010 10:46 pm    Post subject: Reply with quote
inbetween the outer part and the threaded inner part
PostPosted: Sun Oct 17, 2010 12:34 pm    Post subject: Reply with quote
Can someone whip out their rubber and measure it please
PostPosted: Sun Oct 17, 2010 12:49 pm    Post subject: Reply with quote
Oh er mrs Laughing
PostPosted: Sun Oct 17, 2010 1:09 pm    Post subject: Reply with quote
Laughing
PostPosted: Tue Oct 26, 2010 9:10 pm    Post subject: Reply with quote
Does anyone have a petrol cap for sale??
seems a waste as I only want the rubber seal.
PostPosted: Wed Oct 27, 2010 11:15 am    Post subject: Reply with quote
It is worth checking other cars. The 75 uses the same fuel cap I think.
However there are a couple of different versions of the same cap (Alfa did a load a few years ago which didn't seem to fit that well) so not certain the seals will be the same.
PostPosted: Wed Oct 27, 2010 12:53 pm    Post subject: Reply with quote
Thanks Keith, I know a 75 specialist, I will ask him
