Posted: Mon Nov 28, 2011 3:10 pm Post subject: Which eletrical fuel pump on a budget? |
Hi guys,
Considering changing to an electrical fuel pump and regulator but on a budget.
Also where can I get the metal plate to block off the mechanical fuel pump opening?
What about this Facet pump and regulator?
[URL="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150703818217"]http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150703818217[/URL]
[URL="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150703846234"]http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150703846234[/URL]
[URL="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190587533395"]http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190587533395[/URL] |
Brit01 Gold Cloverleaf
Posted: Mon Nov 28, 2011 7:04 pm Post subject: |
thks Oggie.
Yes those ones (very popular and good) I saw but are a bit out of my budget.
Of course if it was a race car I would go for these but just for daily driving I thought the facet would be fine.
Also still looking for a course for the blanking plate.
Any ideas/ _________________ S2 33 1988 1.7 QV
Posted: Mon Nov 28, 2011 8:55 pm Post subject: |
ok was chatting with woody on the other forum and we have come up with a plan.
A cunning plan.
Buy the push type facet pump with plastic casing - 4 psi.
Fit it just on the outlet of the fuel tank where the rubber pipe joins it.
Use my broken rear demister power line to hook up to the pump and use the cabin demister switch to control the pump.
I could have the switch inside reversed so when it's depressed the pump comes on when the ignition is turned on before the starter motor is turned on.
If I need to overide the pump and turn it off then just press the demister button!
