Posted: Sun Oct 07, 2012 8:35 pm Post subject: Phone call...."Darling i've Broken Down" |
My better half phoned me on Tuesday quoting the above phrase...... i went out to her.......i found her in her lovely freshly panted red M reg 16v........parked on the side of the road......i opened the bonnet......... i believe my next sentance was "ah, that shouldn't be there!",........ as i looked at the snapped cam belt that had burst it's way through the plastic covers!
So the next month is an engine out, replace head & broken bits task. fantastic!
Still you have to laugh
_________________ 155 sportpack
Posted: Mon Oct 08, 2012 8:24 am Post subject: |
Sounds like she was over revving it... _________________ If it aint broke, fiddle with it until it is!
Posted: Fri Oct 19, 2012 11:15 pm Post subject: |
She was in a traffic jam & had just put it into 2nd, only just moving fast enough to make the speedo needle move. _________________ 155 sportpack
Posted: Fri Oct 19, 2012 11:17 pm Post subject: |
I'm getting there, the o/s belt had snapped, by middle of next week the replacement head should be on & by the end of the week i'm hoping to fire the monster back up. Just in time for the MOT to be due! _________________ 155 sportpack
Posted: Sat Oct 20, 2012 6:48 am Post subject: |
It seems the 16v belts snap more easily than the 8v ones.
I hope the crankshaft bearings weren't squashed..best of luck. At least she wasn't red-lining it!
eagle3 Alfa 33
Posted: Sat Oct 20, 2012 7:12 am Post subject: |
Sorry that was me ^ _________________ Alfa33 QO 1984
Alfa33 1.3i.e. 1994 |
Posted: Sat Oct 20, 2012 11:38 am Post subject: |
Good work, hope it's all sorted soon.
Do you know how old the belts were?
Are you not tempted to drop in the 9k miler you have on ebay?
Posted: Sun Oct 21, 2012 9:08 pm Post subject: |
Yes I considered fitting new belts to the 9k engine I've got & fitting that (would be less work than repairing this engine), but I could really do with the £s that low mile engine will bring in, I have all the bits to repair the damaged engine so made sense to bolt them on. _________________ 155 sportpack
Posted: Thu Nov 01, 2012 6:17 pm Post subject: |
She runs!!!!! and what a sweetie. 1st turn of the key, such a relief. The Mot has expired while it's been off the road, it needs brake cylinders, a front ball joint and a small plate welding at the front so not too bad, will be back on the road all sorted next week. _________________ 155 sportpack
