Air filters for 16v without plenum chamber
PostPosted: Tue Oct 30, 2012 8:06 pm    Post subject: Air filters for 16v without plenum chamber Reply with quote
Anyone done this?
The distance between each throttle is 100mm, I think this is simular to IDA's, I cant find anything to fit, any suggestions?
PostPosted: Fri Nov 09, 2012 2:39 pm    Post subject: Reply with quote
I just took delivery of these, K&N 56-9252
http://www.knfilters.co.uk/search/product.aspx?Prod=56-9252
The distance between the pillers is 155mm, i need 165 for my trumpets, so i need to move them and drill 2 40mm holes in the baseplate 100mm apart.
PostPosted: Fri Nov 09, 2012 11:04 pm    Post subject: Reply with quote
How do you bypass the AFM/ idle control valve then?
PostPosted: Fri Nov 09, 2012 11:18 pm    Post subject: Reply with quote
Im running an aftermarket ecu, omex 500.
been having some fun with it of late.
to get through emissions, i just went to the fuel map, highlighted rev rand 800 - 3600 and lowered the amount until it passed, then put it back to normal.
