ad87 Alfa Arna
Posted: Sun Sep 07, 2003 10:13 pm Post subject: Just one page... |
I finally found a workshop manual for 33.It is in french everything OK but on the page 04-14 the old user gets some brake fluid.Coud somebody send it to me by e-mail?Please?
It is an '84,"Direzione assistenta" and the missing page contains informations for adjustement of twin Dellorto's. _________________ Please,I need to know the level in the float chamber for the DELLORTO 40DRLA(Alfa 33,1.7).Can I find a Manual to download for the 2' series? |
Posted: Mon Sep 08, 2003 10:47 am Post subject: |
For the float hieghts, etc, check
http://www.alfa-pages.co.uk/carbjet.htm
The original Alfa 33 workshop manual did not have the pages on setting up the twin carbs. This was added later. Think Scott Sanders web site has the (English) pages which you can download.
ad87 Alfa Arna
Posted: Mon Sep 08, 2003 8:48 pm Post subject: |
On the Scott's site it's the 83 Manual,and some missing pages from an 84 Manual,but isn't about models with dual carburetors.I need it from an editon after or including 84 Workshop(if anybody has a scanner). _________________ Please,I need to know the level in the float chamber for the DELLORTO 40DRLA(Alfa 33,1.7).Can I find a Manual to download for the 2' series? |
Eddie W Alfa 33
Posted: Mon Sep 08, 2003 10:47 pm Post subject: |
Float level for the 36 Dellortos is 5-6mm. This is probably a good starting point for the 40s. If you`re running rich, check your float weights(10gms) as they seem to get heavier over time and consequently stuff up the fuel level. This is quite crucial to power and economy. Float setting is of course the gap between the float bodies and the the carb top. You need to bend the tag that operates the needle valve to adjust.
Regards Eddie |
