adamcookie Alfa Arna
Joined: 16 May 2014 Posts: 12 Location: Bristol, Somerset
Posted: Mon Dec 29, 2014 5:39 pm Post subject: Few questions - fuel relay |
Hello all, and merry christmas.
Trying to get my head round the 16v fuel quality relay. I apologise for my ignorance.
Could someone explain to me what each of the relays in the pictures are - and if it looks correct. Im assuming i have the yellow (95 ron with cat) relay? I have no idea which ones connector s30. It looks like a different setup to every picture i have found!
The car is a 1993 16v with cat.
I use 98 ron, but i'm assuming the 16v doesn't have a knock sensor? so will this make any difference at all?
Thanks - im getting there haha |
Posted: Tue Dec 30, 2014 10:29 am Post subject: |
That all looks fine Adam.
My car is a '93 catted 16v too. I'll try and get out to confirm later and take a picture.
From memory the yellow one is the fuel pump relay and the red stripe one is ignition relay.
Posted: Tue Dec 30, 2014 2:10 pm Post subject: |
Ok here are mine.
I replaced the fuel and ignition relays a few years ago as they packed up together for some reason- they are just basic relays- don't think they are anything to do with fuel quality- might be wrong. Mine were originally like yours- 1 mustard colour and one red stripe.
I've never touched the other group of relays shown- these are how mine have been since 2001 and probably since the car was made.
Hope that helps!
 _________________ If it aint broke, fiddle with it until it is!
Posted: Tue Dec 30, 2014 10:12 pm Post subject: |
beware, Bosch relays with a red stripe on the metal housing (like the one on your first picture) are diode-protected and shall be replaced with a similar item
Posted: Mon Jan 05, 2015 11:28 am Post subject: |
Ah thanks,
That thread with JeremyC is the same car! I bought it from him back in April.
There is no sign of that orange plug. (see top pic) Bit confusing - although it does look the same as john 33's set up.
Does not having this plug mean I should be running 98? or is it just hidden somewhere else? |
Posted: Mon Jan 05, 2015 11:29 am Post subject: |
| sorry forgot to sign in! |
Posted: Mon Jan 05, 2015 12:33 pm Post subject: |
I wouldn't worry too much about it Adam. Are you having any running issues?
The fuel pump relay in mine now is a genuine bosch part 0332 014 112 and I assume it's diode protected from the diagram on the side. It came like that -plastic/ no red stripe in 2012.
The ignition relay (the black one) is a generic ebay part. I couldn't get the original Italian made mustard colour one with the orange base anywhere.
Posted: Tue Jan 13, 2015 9:27 pm Post subject: |
Adam...........Pop round. _________________ 155 sportpack
gurgaonnight Guest
Posted: Tue Nov 25, 2025 6:34 am Post subject: services |
| People searching for trustworthy and well-mannered companionship often share their feedback online. They say their overall experience becomes smoother when choosing Gurgaon Escort , especially because the individuals maintain good communication. This balance of safety and comfort makes the service appealing to first-time users. |
