guest Guest
Posted: Sat Sep 20, 2003 12:02 pm Post subject: previous starting problem come back to haunt me |
This alfa 33 1.5ie 1990 bosch jetronic will not start unless coaxed by spraying petrol into the air cleaner once started it runs just fine. We have had the air flow meter apart and cleaned and adjusted it and also replaced the cold start temperature sensor which worked for a while. However it has started to not start if you see what I mean. |
galaxierog Alfa Arna
Joined: 12 Jun 2003 Posts: 14 Location: Birmingham, England
Posted: Sat Sep 20, 2003 6:22 pm Post subject: |
further info on galaxierog I found my original password at last. |
