neo Alfasud
Posted: Mon Sep 22, 2003 7:53 pm Post subject: Lights |
Hi !
How can I change the lights behind the speedo and the rev meter, and the ones behind the air&fan conrtol panel.
Thanks! |
Posted: Mon Sep 22, 2003 8:08 pm Post subject: |
To change the bulbs in the speedo you must undo the two screws that keep in place the speedo black cover, and the undo the for screws that hold the speedo itself- two of them are at the back of the speedo on two brackets and the other two are under the aluminium holder. Then it is easy to find the bulb.The same is with the air/fan controls. But you will need a small mirror to see by placing it behind the small object holder under the heater controls.
Hope this helps,
neo Alfasud
Posted: Tue Sep 23, 2003 11:10 pm Post subject: |
Hi!
I've manage to change the lights of the speedo and the rev meter, but I can't take out the fan control panel.
Can you give me more details?
Thanks! |
Posted: Tue Sep 23, 2003 11:32 pm Post subject: |
Try to remove the object holder underneath the fan controls - You may also remove the radio receiver if possible in order to gain access both upside and downside.
Then fit a small mirror and use a small torch in order to see what going on behind the contol panel.
I would not try to remove the whole fan control system as has various control cables operating the front, winscreen, and feet ventilation system.
It may not be easy to work it out with the mirror but i think it is much more safe because there are various connectors of the heating system which may be streched.
We ll wait for your news, _________________ Thanassis Gritsopoulos
Marcin Alfa Sprint
Posted: Wed Sep 24, 2003 8:37 am Post subject: |
when you remove the panels that hold the standard front speakers, then on each side of the middle console you will see one screw. Those hold the heater and ventilation control unit in place. When you remove the bolts, you will be able to turn the unit slightly in order to get a better access to the back of the unit where the bulbs are located.
Marcin |
neo Alfasud
Posted: Wed Sep 24, 2003 2:02 pm Post subject: |
Thanks!
I'll let you know if I managed to do it. |
BILL Alfa Sprint
Posted: Wed Sep 24, 2003 8:26 pm Post subject: |
Speaking of lights,has anyone changed the front light bulbs with something better?
I use PIAA Extreme White and the difference is very big.PIAA are very expensive but i have very white light at night (the brightness is close to xenon lights) and more relax night driving. |
Dave_NZ Alfasud
Joined: 13 Mar 2003 Posts: 56 Location: Amsterdam, NL
Posted: Thu Sep 25, 2003 12:32 pm Post subject: |
how much did the lights cost. have they lasted very long. i am keen to get some brighter lights for my s2 qv. did you need to do any rewiring. thanks
Dave _________________ Looking for a type 2 33QV in NL |
BILL Alfa Sprint
Posted: Thu Sep 25, 2003 3:51 pm Post subject: |
Dave_NZ wrote: |
Dave |
Hi Dave,
they cost 150EURO 18 months ago (very expencive ,but worth every cent i payed ),and they are still working fine.Its was very easy to replace them and no rewiring was needed,simple as change the lamp in a car. |
Maximilian Alfasud
Posted: Mon Sep 29, 2003 10:59 am Post subject: |
I would be too afraid to out uprated bulbs on my car. The lamps are in perfect condition - with none of the silver peeling inside.
If the uprated bulbs damage them in any way it would be nearly impossible to find some like these again. _________________ 1988 Sprint 1.7 QV (35,000 miles) |
Rob Currie Alfa Arna
Joined: 29 Sep 2003 Posts: 5 Location: Irene, South Africa
Posted: Mon Sep 29, 2003 7:37 pm Post subject: |
One thing I learned from years of rallying is that halogen bulbs deteriorate with use and should be replaced every couple of years, depending on use.
Rob |
