graeme Alfasud
Posted: Tue Oct 07, 2003 5:23 pm Post subject: 16V Senders |
Need to verify function of four senders on the 16V engine.
For RHD car positioned as follows:-
1 Centre rear of block ( oil presure I guess)
2 Rear of nearside head ( single spade connector).
3 Nearside throttle body ( 2 pin).
4 Offside throttle body ( single spade connector) _________________ 16v p4 In pieces. |
john w 16v Guest
Posted: Thu Oct 09, 2003 6:22 pm Post subject: senders |
Hi, From memory-
IF NEAR OIL PUMP ITS THE OIL PRESSURE- SEE BELOW
TEMP FOR TEMP GAUGE
TEMP FOR ECU
SOUNDS LIKE OIL PRESSURE AGAIN??
There are also the sender for the timing (ECU) from flywheel on n/s/r and the throttle postion switch on o/s/f throttle choke.
The engine harness also connects to the injectors and the idle valve on the front of the manifold.
Hope this helps a bit,
John '93 16v |
graeme Alfasud
Posted: Thu Oct 09, 2003 6:29 pm Post subject: Senders |
Thanks,
OK apart from the single spade connector on the o/s throttle body. Can't be oil pressure, aint no oil in the throttle body! _________________ 16v p4 In pieces. |
johnboy 16 Valve
Posted: Thu Oct 09, 2003 7:45 pm Post subject: Re: Senders |
graeme wrote: |
Thanks,
OK apart from the single spade connector on the o/s throttle body. Can't be oil pressure, aint no oil in the throttle body! |
hi there,
i think that's the water temp sender,i'm sure it is.
hope that help's
1999 freestyle superjet |
graeme Alfasud
Posted: Thu Oct 09, 2003 8:13 pm Post subject: Senders |
I would have thought so. So what's the single spade connector on the back of the nearside head? _________________ 16v p4 In pieces. |
john w 16v Guest
Posted: Thu Oct 09, 2003 8:37 pm Post subject: |
Just looked at handbook, and it says that the sender on the OSF throttle is temp. Again from memory i think there was a brown wire to this one and an orange wire to the oil pressure (i think!!??)
I remember the single spade on the nsf head (had this head off twice) but can't fathom what the connector could be for except temp? I'll have to have a look at the car at some point now!!- I'm sure it all made perfect sense when I put the engine back in the 2nd time!!
John |
