Adam H Alfasud
Posted: Wed Oct 29, 2003 8:14 pm Post subject: 16v Water Pump |
Whilst I have my engine still in little bits, I'm considering changing the water pump.
What are the symptoms of a knackered pump?
If it isn't knackered I won't change it but I believe inspection is impossible as they have to be removed with a hammer! |
johnboy 16 Valve
Posted: Thu Oct 30, 2003 12:41 am Post subject: Re: 16v Water Pump |
Hi there,
it will start to nock and then water will pore out, i replaced one on my twin carb and your right it's hammer time if you've got the engine apart you mite aswell do it if your not happy with it.
hope that help's
1999 freestyle superjet |
Rob (not an ARNA) Guest
Posted: Thu Oct 30, 2003 6:37 am Post subject: |
Adam,
I have found from a rebuild of a Renault engine in the past that if you leave the water pump dry for any length of time, the seal dries out slightly. The result is a leaking pump when you put it all back together again. My advice is replace the pump now if it has done any reasonable mileage, regardless of condition. It is 10X easier to do with the engine out of the car.
Rob |
Posted: Thu Oct 30, 2003 10:40 am Post subject: |
A would like to make a question which is more or less a statistical one.
My car has now done 76.000 kms and it is 12,5 years old - do you think that the pump has still many kms to do or at a certain age do they fail?
I replace coolant once a year and the cooling system does not indicate presence of corrosion (brown liquid)
More over the pump does not make knocking sounds - it is like when the car was new.
Thanx _________________ Thanassis Gritsopoulos
johnboy 16 Valve
Posted: Thu Oct 30, 2003 10:57 am Post subject: |
[quote="gritsop"]Hi,
Hi gritsop
you've just answered your own question,no it does'nt, i changed mine at about 88000 mile's, so there should be quite abit of life left in it,but then again it could fail in a couple of thousand miles.i would think your ok though.
all the best john _________________ WODA WE NEED? MORE POWER!!
Rob (Perth) Guest
Posted: Fri Oct 31, 2003 6:36 am Post subject: |
Hi Thanassis,
My first water pump lasted 75,000 km. The second one is still going after 105,000 km with no bad signs yet.
I think that water pumps fail quickly if the engine is not run frequently. My first pump failed after my car had been in storage for a year.
Rob |
