		scotauto Alfa Arna
				 Posted: Mon Dec 01, 2003 10:18 pm    Post subject: engine swapping |
				how easy and what is required to fit an injection engine from a 1993 alfa 33 into a 1986 model?
My local scrappy has one and I've got an alfa 33 without an engine (as well as my daily driver!!)   _________________ Hope for the best when you press those brakes!!!!!!!! |
		Ketil-no Alfa Arna
  Joined: 08 May 2003 Posts: 20 Location: Bergen-Norway
				 Posted: Thu Dec 04, 2003 7:33 am    Post subject: Re: engine swapping |
	  | scotauto wrote: |
My local scrappy has one and I've got an alfa 33 without an engine (as well as my daily driver!!)   |
Take a search on the forum. I guess you will find all the answers that you are after. If not try to be more spesefic. For instance what type of moter are you thinking of? 8v? 16v?
I am not trying to be a smart arse, just give an friendly andvice....
Regards Ketil |
		johnboy 16 Valve
				 Posted: Thu Dec 04, 2003 8:32 pm    Post subject: Re: engine swapping |
				[quote="scotauto"]how easy and what is required to fit an injection engine from a 1993 alfa 33 into a 1986 model?
Hi there,
easy! i did a swop with mine  an 8v series 2 and put a 16v in it with the injection. if it's an 8v injection it will be easyer, as you wont need the crossmember but you will if 16v.just keep the injection loom with the engine.that way you know it worked when you took it out of the car,just disconect the ECU instead of disconecting everything.but the 8v injection system is a bit different from the 16v system. people say you will need the injection fuel tank but i kept the carb one and have had no problems.just lucky i think.i did mine on a mates drive.just jack the car rite up and lower the the engine and box down as one on to another jack.if you need anymore help let me know.
all the best john _________________ WODA WE NEED? MORE POWER!!
1999 freestyle superjet |
