matt33 Alfasud
Posted: Fri Feb 17, 2006 7:17 pm Post subject: speedo problems,,,,,Help!!! |
Sorry if this has been covered before,but the speedo on my 1994 cloverleaf has recently started acting strange,after about 5-10 minutes of driving the speedo needle starts moving around eractically,but only for a second then back to normal then up and down again,,,, it seems ok when she is cold but when warm it starts to happen, ive tried a sharp whack on the top of the console and nothing has happened,,so any help or advice would be most welcome,,,looks like another expensive trip to the garage ,,,thanks for any help, matt |
Posted: Sat Feb 18, 2006 11:39 am Post subject: |
First check the wiring joint (box connector) near/under the clutch fluid reservoir where the gearbox sensor lead joins lead heading through bulkhead into the dash. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
matt33 Alfasud
Posted: Thu Mar 09, 2006 7:03 pm Post subject: |
| cheers for your help,,had a fiddle around that area and it has been working ok for a while now,,,thought i was in for a big bill there!,,,,,thanks |
Posted: Sat Mar 11, 2006 9:23 am Post subject: |
| My rev counter and my temperature gauge both do that occasional-waving-around-a-bit thing. I thought I'd sprayed some cleaner into the plugs near the master cylinder, but perhaps I better try harder. |
