BillaBoo Guest
Posted: Thu Dec 16, 2004 12:04 pm Post subject: Gearbox for 92`Alfa 33 1.7 16v QV wanted! |
i am looking for a gearbox for my 1992 AR 1.7 33 16V QV. It need to be in good condition. i dont want a gearbox that makes nasty noices when you shift to 2nd gear.
As few miles as possible would be appreciated. |
BillaBoo Guest
Posted: Thu Dec 16, 2004 9:49 pm Post subject: |
i am in Sandefjord, Norway. I`ll pay shipping .. or i`ll come fetch it myself
Got anything of my interest?  |
Posted: Thu Dec 16, 2004 11:23 pm Post subject: |
QV just means green cloverleaf yes? Not P4? I have a standard 16v gearbox from a K reg 33 going for £60. It was fine when it was in the car. Surely someone in Norway must have one. The shipping costs would be huge. If you're mad enough to get it I'm in the south of England, near Brighton. Mileage was about 80,000. Perhaps look around and see if someone can do you a better deal first? What happened to the old gearbox? Good luck, Paul. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
BillaBoo Guest
Posted: Mon Dec 20, 2004 1:35 pm Post subject: |
QV is not P4
Alfa 33 is a rare car in Norway, so not many gearboxes to choose from. And most of them is like mine.
The original gearbox had to much wear. From 1st to 2nd it was awful. The gearbox screeeaaaaammeeed in pain. The normal 2ndgear-problem. Synchronizing rings? or.. bad synchronized. dont remember exactly.
THen i bought a new one, that was suppose to be fine. But this also has the little problem with 2nd gear.
Is there a way to fix it?
Dont wanna go over the WHOLE gearbox, as it will be way to expensive. |
Posted: Tue Dec 21, 2004 11:45 pm Post subject: |
There is a knack to changing to 2nd without doing damage, but the more damaged the syncro, he harder it is to change into 2nd cleanly. Sorting out the linkage ends at the bottom of the gearstick and near the entry to the gearbox can sometimes help a bit or adding an additive to/topping up/changing the gearbox oil is another possibility, but you won't get miracles. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
BillaBoo Guest
Posted: Sat Dec 25, 2004 6:26 pm Post subject: |
i just double-clutch or shift slowly .. then it works fine, but i found a topic here, were "wizz" has fixed the synchro`s.... he`s now my hero.
so i`ll try to fix one of my gearboxes myself  |
