Posted: Sat Aug 20, 2005 10:06 am Post subject: camshafts boxer 1.7 vs boxer 1.5 |
I was wondering... is it possible to use 'hot' camshafts from a tuned boxer 1.5 in a boxer 1.7? (both carb-engines)
the boxer 1.7 is to be completely overhauled in the very near future, and now I got this offer for the camshafts... and they're not exactly expensive... and almost never used so... is sounds like an attractive offer! But... will it fit? And run? I know the 1.5 and the 1.7 engines are very similar, only bore and stroke of the pistons are different but... are the cilinderheads similar or not?
Tnx  |
Posted: Sat Aug 20, 2005 10:29 am Post subject: |
| Oh, I forgot; both engines now have the non-hydraulic valve heads on them |
Posted: Sat Aug 20, 2005 11:37 am Post subject: |
The 1.7 heads have a bigger inlet and slightly bigger ports and chamber. if it already has solid lifter cams then I don't see any reason why not. _________________ A LITTLE FURTHER A LITTLE FASTER |
Serpent33 Alfa Sprint
Posted: Fri Sep 02, 2005 2:29 pm Post subject: |
Pls note Solid lifted and hydrualic lifted cams are NOT INTERCHANGABLE. Good luck. _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
