Switches Swap
Bellamachinna
PostPosted: Wed Dec 14, 2005 12:44 am    Post subject: Switches Swap Reply with quote
Hi all Very Happy
My 16v has the big square switches for the rear demister, hazard lights, front & rear fog lamps... Rolling Eyes
I bought the smaller and more recente ones with sockets included... Razz
My nightmare started, when i tried to adapt these to my car wiring... Shocked
Ex: The hazard lights switch, on my car has 6/7 wires connected to it...
The "newer" switch only has 4 wires, and one of them isn`t even mentioned in the wiring diagrams Shocked Shocked
The wiring diagrams dont cover these newer switches... Confused
Anyone has some sort of supplement that cover these newer versions??? Wink
Thanks in avance Very Happy
P.Camilo
Ben_nz
PostPosted: Wed Dec 14, 2005 6:02 am    Post subject: Reply with quote
Newer versions? I never heard of those, what car do they come out in?
I got a second hand square switch out of a series 3 33 and I noticed they'd improved the backlighting, but that's all.
tvatavuk
PostPosted: Wed Dec 14, 2005 1:00 pm    Post subject: Reply with quote
33 S3 from 93-94 used new switchs, about 1/2-3/4 width of our normal square ones Smile
I have removed one of those new type hazard lights switch from Q4 SW, and runned into same problem as P.Camilo has.
Tino Vatavuk
Bellamachinna
PostPosted: Wed Dec 14, 2005 4:57 pm    Post subject: Reply with quote
They camed from a Series 3 , 33 Imola, a special version with the looks of the 33 16v, but with the 1.4 IE engine.
They look like this:
Sorry for using someone else picture. This picture can be found in http://alfaimola.free.fr/, web page from a user of this forum - ZeNiTh-PbArM. Great web page, with very good tips...
Have you give up??? - This weekend i will take my multimeter out of the box, and will give it a try. The hazard switch, has 9 pins, but some of them are used for ilumination, and behind the connector, they bridge with another pin...This is most notorious in the ground wire (black one)
P.Camilo
bobbber
PostPosted: Wed Dec 14, 2005 5:46 pm    Post subject: Reply with quote
Here's a question. Some of my switch lights on the dashboard (the big square ones) are lit up dimly when not switched on, and bright when they are switched on. However, most have no dim light when off.... are they ALL supposed to be dimly lit whilst off?
Bob
Fiat Bravo 165 Sport
Bellamachinna
PostPosted: Thu Dec 15, 2005 12:20 am    Post subject: Reply with quote
It depends...
The hazard lights switch, and the rear demister have to be on all the time (with ignition on). The smaller light (color coded) only cames on when switch is on, on all switches.
The front fog ligts switch, gets illuminated, with the position lights, and if you press it , the rear fog lights switch also gets illuminated (and serviceable).
If your car doesn´t have front fog lamps, then the rear fog lamp switch only illuminates, when you turn on the driving lights.
(this is due to EURO regulations).
If your switches look badly lit, thats because, they use a small lamp, equal to those used on the instrument cluster, in a plastic "carrier", that gets yellow with the heat generated by the lamp...
(my hazard lights switch is so badly lit that you can never say that is illuminated at all)...
This is because when they are pressed they are closer to this small plastic carrier and the light is closer to the top of the switch.
Hope this helps
P.Camilo
gritsop
PostPosted: Thu Dec 15, 2005 12:38 am    Post subject: Reply with quote
and I 'd like to add that if you try removing the transparent plastic lamp holder it will probably brake as heat of the lamp has weakened the plastic.
I ruined two switches trying to remove the bulb - heated window and hazard lights. At the end I bought two new ones at 30€ both.
Thanassis Gritsopoulos
Ben_nz
PostPosted: Thu Dec 15, 2005 9:02 am    Post subject: Reply with quote
The switches are supposed to be backlit only when they are selectable. So the foglight switches won't be backlit unless you have the headlights on, because pressing the foglight switches with the headlights off wouldn't do anything.
To get around the plastic bulb holders going yellow, cracking and not allowing light through, I threw them away.
If you try for a long time, it's possible to plug the bulbs in without using the bulb holders.
Then you'll get strong enough backlighting of the switches that you can almost notice it.
That is, if you can see the switches at all because Alfa cunningly placed them all exactly behind the arms of the steering wheel. Rolling Eyes
bobbber
PostPosted: Thu Dec 15, 2005 12:07 pm    Post subject: Reply with quote
So the small 'led' part of the lights are supposed to be lit up at all times?
Fooey... mine aren't! Are the switches just a push fit (i.e. can be leavered out)?!
Bob
tvatavuk
PostPosted: Thu Dec 15, 2005 12:33 pm    Post subject: Reply with quote
Backlight comes from small bulb like in instrument panel
LED part is on when you press switch if it's servicable (backlight on).
P.Camilo, yes I gave it up, because my normal switch is working, I just wanted to insert one switch more there, without ruining 33 looks.
regards
Tino Vatavuk
Bellamachinna
PostPosted: Thu Dec 15, 2005 3:34 pm    Post subject: Reply with quote
Hi Very Happy
My hazard lights switch, has "left the building" Sad Problem is that the direction indicators, also went dead, because of it... If this switch dies all the indicator ligths die.. Sad
The rear demister switch, also has no illuminattion at all (and the bulb is new)...
The only switches that are working are the switches for the front and rear fogs...
I always, liked the look of the smaller switches, and as i found those very cheap, i tought to give it a try Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad
P.Camilo
Horizontally Opposed
PostPosted: Sun Dec 18, 2005 2:41 am    Post subject: Reply with quote
Ok this is very interesting since I have NEVER seen my switches light up (all except the hazard lights switch which lights up fine...)
Everything else works just fine so I was wondering: is there is a fuse especially for the switches lighting?
bobbber
PostPosted: Sun Dec 18, 2005 3:58 pm    Post subject: Reply with quote
I've changed all my bulbs in the switches.... 5 minute job. MOST were blown. I'd look here before the fuses - as the fuses generally affect more than one part of the system.
Bob
PostPosted: Sun Dec 18, 2005 9:44 pm    Post subject: Reply with quote
I do have the wiring supplement for the later cars now. Should be scanned in soon.
Bellamachinna
PostPosted: Wed Dec 21, 2005 5:44 pm    Post subject: Reply with quote
Hi Keith
Can you scan the page that covers the hazard lights, and send it to my mail?
The other switches are easy to convert, as they use the same number of wires - 4 (although some of the wires use diferent colors).
The hazard lights switch is a real pain. It has 9 pins, with even more wires coming into the connection socket...
The "new" switch only has four wires...
I´m trying not to cut, the original electric instalation. So i already got sockets that connect, on the original ones...
The other switches are "ready to go", but the hazard swicth, i dont know how to connect it...
My mail is PJOCamilo@Hotmail.com
Thanks in advance
PostPosted: Wed Dec 21, 2005 11:24 pm    Post subject: Reply with quote
Hopefully scanned in soon. At my better halfs work they have some high speed scanners in to try out Wink .
