Cheepest belts and pulleys.
Edward
PostPosted: Tue Mar 21, 2006 10:18 pm    Post subject: Cheepest belts and pulleys. Reply with quote
Hello,
Where is the cheapest place to get a set of belts and pulleys for a 16v.
They do not seem to come up on Ebay very often!
The faster the better.
tvatavuk
PostPosted: Tue Mar 21, 2006 11:49 pm    Post subject: Reply with quote
I hope you 're looking only for pully bearing and not complete arms?
If that is case you should be able to buy all needed bearings from SKF importer.
Tino Vatavuk
hugh jinjin
PostPosted: Wed Mar 22, 2006 9:09 am    Post subject: Reply with quote
give alfashop in norwich a call
Edward
PostPosted: Wed Mar 22, 2006 8:01 pm    Post subject: Reply with quote
Thanks Hugh,
I did give Justsuds a ring and they are coming back with a price.
On the subject of what to buy I would have thought you can not just get away with the bearing as I have seen some where the wheel colapses - or does the wheel only colapse once the bearing has failed?? It would be a shame to replace the bearings and belts and have a wheel colapse 6 months later.
Any ideas?
tvatavuk
PostPosted: Thu Mar 23, 2006 8:48 am    Post subject: Reply with quote
When I said bearing, in this case it is actualy - SKF metal bearing with outer plastic shell(wheel?) which guides belts.
People usualy have hell of time serching for complete pully arms which hold bearings along with tension springs. Idealy it would be good to replace them, but:
Original
a) hard to find
b) their price is sky high
Nonoriginal
c) less hard to find
d) still expencive
e) in many cases worse in quality then one on your alfa
So as you see, if pully arm or spring are ok, there is no need to replace anything but bearing (which is comming with new plastic outter housing).
Many 8v (have ony 2 bearings) but they must be replaced along with arms.
Tino Vatavuk
Edward
PostPosted: Thu Mar 23, 2006 10:37 am    Post subject: Reply with quote
Thanks Tino,
I have had a quote of just over £100 - for belts and pulleys- but I do not know the full extent of what is on offer. I will give them a call and see what is included - I will let you know.
Edward.
johnboy
PostPosted: Thu Mar 23, 2006 1:23 pm    Post subject: Reply with quote
Hi Edward
Just checked a bill from 3 years ago when i did my 16v and £100 sounds ok.=2 belts 4 idler pulleys .i was told that you have to press on the pulleys,on the the arms?
hope this helps john
WODA WE NEED? MORE POWER!!
1999 freestyle superjet
markgp4
PostPosted: Thu Mar 23, 2006 3:55 pm    Post subject: Reply with quote
Edward,
if its not too late Alfashop in norwich did me 4 pulley wheels and 2 belts for .... er...
24.54 belts
34.40 for wheels
plus VAT
about a month ago.
cheap as chips....
( if theres a tato famine ... Wink )
Mark
make it go faster Smile
PostPosted: Wed Mar 29, 2006 10:48 pm    Post subject: Reply with quote
Mark,
That sounds great - less than £70 inclusive of the vat is pretty good. I think I will give them a call. How do you get the old pulleys off the spindles??
Edward.
markgp4
PostPosted: Wed Mar 29, 2006 11:02 pm    Post subject: Reply with quote
the ones on threaded bolt just taps off..
other pair a (motor) engineering shop £10 press off old and new on.
best of luck mate Smile
Mark
john
PostPosted: Thu Mar 30, 2006 8:56 am    Post subject: Reply with quote
Try pressing with a good vice / sockets etc first, and save another tenner!
Also may be worth thinking about the waterpump, and alternator/pas belts whilst it's all off.
tvatavuk
PostPosted: Thu Mar 30, 2006 1:40 pm    Post subject: Reply with quote
If you haven't changed waterpump in last 6-12 months, don't even think about not replacing it.
Replacing it now with quality one is cheapest.
Cheers
Tino Vatavuk
