Posted: Mon Apr 10, 2006 4:09 pm Post subject: Gearbox differences... |
Hi all
This topic, has already been covered, but i cant find it...
My gearbox, started to give up on me, and i cant find a good one from a scrapper...
My car is a 16v. I already considered a gearbox from a 145/6 1.7 16v, but the supports are completly different.
My question is this:
The gearbox ratios are the same between 1.7 and 1.5??
I also remember, someone saying that the gearbox from the 16v, has a "special" hole for the RPM sensor from the Motronic...
Is this correct??
If this is correct, does the gearbox from the 1.5 IE, features that "hole"???
Also, if that is correct, the gearboxes, from carbureted cars, cant be used on injection models.
Is this correct??
Thanks in advance
for yor help
Posted: Thu Apr 13, 2006 11:39 pm Post subject: |
Anyone????????????? _________________ All'interno della mia macchina, vi sedete, tenete sopra e CHIUDETE IN SU... |
Posted: Fri Apr 14, 2006 7:53 am Post subject: |
According to the Alfa documentation - the 1.5, 1.7 and 1.7 16v gearboxes are the same part numbers.
Posted: Fri Apr 14, 2006 9:56 am Post subject: |
The gearboxes are fairly similar, though somebody once said there were extra strengthening fins on the 16v one??? The overall gearing on the 1.5 definitely seems shorter than on the 1.7. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Ian M Green Cloverleaf
Posted: Sat Apr 15, 2006 1:28 pm Post subject: |
According to the table on this site (4th icon from left at top) all the series 3 gearbox ratios are the same apart from the 1.3 which has a slightly shorter diff. _________________ Presntly own
Red Abarth 500c |
Posted: Sat Apr 15, 2006 2:16 pm Post subject: |
Hi again...
| Quote: |
| According to the table on this site (4th icon from left at top) all the series 3 gearbox ratios are the same apart from the 1.3 which has a slightly shorter diff. |
Yes, i`ve already, been there... But my doubt, still remains...
The "best" gearbox that i found cames from a carbbed 1.5 (series3)...
I say "best" because i am taking the onwer word for it ( its a good friend thats living at 350 Km from me).
But i`ve heard that, in order to fit the 16v engine the gearbox case MUST have a place, were to insert the RPM sensor...
Carbbed cars, didn`t have this sensor, and i was told to get a 16v gearbox only (as i dont intend to swap gearbox internals).
I never saw a 1.5 gearbox, out of the car... But did the 1.5 IE also had a RPM Sensor???
Also, i dont want to travel 350 km, just to find out that the gearbox wont fit my car...
I compare this case, with engine block predisposition to mechanical fuel pump (carbbed cars) and blanked ones for injection models...
Serpent33 Alfa Sprint
Posted: Mon Apr 17, 2006 6:57 pm Post subject: |
To my knowledge, All 33's uses the same sensor. My 84 S1(carbed) and 91 S3 are the same and interchangable. The geared spedos were found in suds. Though I remembered the housing or linkange varies slightly, can't remember what exactly but does not interfere with swapping. _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
Posted: Tue Apr 18, 2006 12:52 pm Post subject: |
Thanks for your input...
But i wasnt talking about speedo sensors.... Those are placed on the right hand side of the gearbox...
I was refering the RPM sensor, on the left side of the gearbox, that connects to the Motronic...  _________________ All'interno della mia macchina, vi sedete, tenete sopra e CHIUDETE IN SU... |
neo Alfasud
Posted: Wed Apr 19, 2006 4:01 pm Post subject: gearbox |
Hi!
I had a 1.3 engine and I've replaced it with 1.7 16V. I'm using the gearbox from the 1.3 engine, and it has that hole needed for the pick-up for the injection. The car is 3rd series.
The only difference between the gearboxes is the shorter diff on the 1.3 engine gearbox so the car won't go over 190 - 200 km/h.
If you find a good gearbox from the earlier version, the hole on the gearbox casing can be easily drilled.
Best regards,
Nenad _________________ http://www.quartermile.ws/forum/viewthread.php?tid=889&page=1 |
