johnhaynes Alfa Arna
Posted: Mon Jul 31, 2006 8:56 pm Post subject: petrol filler pipe |
| At the point where the petrol filler pipe goes through the body on the series 2 Alfa 33 the body work is double skinned. Does anyone know how can you prevent the water seeping between the two skins? Thanks |
Posted: Mon Jul 31, 2006 10:24 pm Post subject: |
I thought you couldn't.
Posted: Mon Jul 31, 2006 11:21 pm Post subject: |
You should use seam sealer and when dry apply an underbody protectant material.. This will prevent water entering between body panels.
There is foam in between the panels; has that wear off ?
