Klc Alfa Arna
Joined: 01 Dec 2003 Posts: 8 Location: Auckland, New Zealand
Posted: Tue Oct 31, 2006 11:27 am Post subject: torque settings for Series 2 Head bolts |
Hey guys,
Am hoping to repair a head gasket this weekend and was wondering
if anyone knows the correct torque settings for the head bolts
on a 1.7L 8v 33 qv ??
cheers
klc |
Posted: Wed Nov 01, 2006 8:25 am Post subject: |
Haynes manual (for the Alfasud or Sprint solid lifter engine with removable cam cover) says 8.3 ~ 8.9 kg f m or 60.0 ~ 64.3 lb f ft.
That's how they write the units.  |
Klc Alfa Arna
Posted: Wed Nov 01, 2006 10:16 am Post subject: |
cheers man,
hope we are blessed with good weather this weekend... the clouds are probably saving it up for Guy Fawkes anyway
klc |
Chris Notsis Alfasud
Posted: Thu Dec 07, 2006 12:50 am Post subject: Some caution needed |
Hi KLC,
Just take note of the following:
When first installing the heads, make sure each head bolt has a smear of oil on the contact surface (not the thread).
After starting, run engine until fan cuts in, then allow to cool completely (overnight), then back all bolts off 1/4 first and re-torque. Some people are happy to drive a car 500 kms before re-torquing, but in the Alfas, even the factory approach has been to use the above method. From an engineering perspective, the engine has not had a chance to be loaded and heated under load - which can cause abnormal warping. If a head has been torqued correctly, then normal warping is within tolerance. In 500 kms, there is a good chance that leaks could occur. In my experience with Italian engines, the initial warm-up, cooling and re-torquing has never led to any problems. Food for thought.
Sequence:
3 1 5
FRONT
6 2 4
(reverse if left bank)
Good luck.
Chris. _________________ Chris Notsis |
