lxb Alfa Arna
Joined: 15 Oct 2006 Posts: 19 Location: Purley, Surrey
Posted: Sat Feb 10, 2007 12:01 am Post subject: Let's play a game of "Guess what's wrong with the 33 to |
Let's start with.... water loss from water pump and corroded elbow behind bulkhead... then, how about BOTH WING MIRRORS and BOTH FOG LAMPS!! STILL!!!!... not forgetting that the engine mounts seem to be made out of PLAYDOUGH! And then there's the leaking sunroof (HOW? How do they do it? Design a car that lets water in about 4" ahead of the sunroof, with NO CLUE why?), the recalcitrant gear linkage (probably related to the engine mounts), the WEIRD lumpy idling which then perfectly corrects itself then gets randomly lumpy again (lambda sensor? Injection? ECU? Vacuum hose? Oh, God)... and finally, onto the car's newest and most fashionable ailment the LEAKING ******G CLUTCH SLAVE CYLINDER IN THE TOTALLY IMPOSSIBLE LOCATION!!!
I feel slightly better now I've got that off my chest. Back on the heart pills again.... sigh...  _________________ K737 MMM... my slightly dog-eared but willing 33 1.7ie 8V. Awwww. |
stedee Alfa 33
Posted: Sat Feb 10, 2007 3:18 am Post subject: |
oh the fun of owning a 33!!!!!!! _________________ brum brum |
Posted: Sat Feb 10, 2007 6:38 pm Post subject: Re: Let's play a game of "Guess what's wrong with the 3 |
| lxb wrote: |
I feel slightly better now I've got that off my chest. Back on the heart pills again.... sigh...  |
Is that all? You've got a good one..He he
The slave isn't that bad, taking off the manifold helps, and investing in a good pair of hook nose pliers is worth it. _________________ If it aint broke, fiddle with it until it is!
Posted: Sat Feb 10, 2007 10:08 pm Post subject: |
The slave cylinder can be real sod if you don't know what you're doing and really easy if you do. There's a post on here somewhere, which helps if you're on your own. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Posted: Sat Feb 10, 2007 11:49 pm Post subject: |
| I've got a sunroof, and I used to get water dribbling in from around the digital clock. I worked out that got in via the radio aerial though, not the sunroof. It doesn't even need to get in between the roof and the base of the aerial either, thanks to the stupid design. It actually leaked around the central mounting bolt, which of course is the lowest point in a kind of water trough in the aerial base. |
Posted: Sun Feb 11, 2007 3:06 pm Post subject: |
| paulhide wrote: |
| The slave cylinder can be real sod if you don't know what you're doing and really easy if you do. There's a post on here somewhere, which helps if you're on your own. |
Mine on the 1.3 is being a pig. The slave cylinder is seized in place. Circlips is off and still no movement.
Posted: Sun Feb 11, 2007 5:04 pm Post subject: |
If you are not worried about the slave cylinder and are replacing it then there is just enough room to hold a small bar on the edge of the cylinder and tap it through the mounting ring with (the side of) a hammer, but be very careful you don't damage the engine-block mounting ring around the cylinder as it can chip off. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
lxb Alfa Arna
Posted: Mon Feb 12, 2007 3:11 pm Post subject: Slave cyl |
Thanks Paul, I might try it. I've seen a repair kit on Ebay, might give that a try. It's that or silicone sealant I think the leaky roof must be a blocked drain pipe, so I'm going to try to push a fine bit of wire through it. Stay tuned for the next episode, "How to remove fine bits of wire from inside your A-pillar".
PS Does anyone have a spare slave cylinder floating around, juuuuuust in case? The car's off the road at the mo, so at least it's not urgent. _________________ K737 MMM... my slightly dog-eared but willing 33 1.7ie 8V. Awwww. |
lxb Alfa Arna
Posted: Tue Feb 13, 2007 1:04 am Post subject: Clutch slave cyl |
Now I can't find it on Ebay!! It was there earlier! Out of curiosity, does anyone know if all 33 slave cylinders are the same? It sure looks like mine...
********Just checked again - turns out it ended at 9pm today, and went for £34. Not exactly a great bargain, but could have been useful. Oh well. _________________ K737 MMM... my slightly dog-eared but willing 33 1.7ie 8V. Awwww. |
Posted: Tue Feb 13, 2007 1:41 am Post subject: |
Yeah, think they're all the same. Cost 20-30 quid new. Be wary of secondhand ones that have been lying around for a while without use. Please find my post on here somewhere, because it's really easy if you know how and a serious pig otherwise. The secret when replacing is keeping the circlip in the right place flat against the engine block mounting ring. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Posted: Tue Feb 13, 2007 12:49 pm Post subject: |
£34 plus postage on top.
Got mine for £20 from Mangoletsi so it was just as well you missed the end of the auction!! |
Vecchio Alfisti Alfasud
Posted: Fri Feb 16, 2007 11:45 am Post subject: |
Two tips for the slave cyclider, hope I am not too late to be of help: 1. With all in place but with the circlip removed, use the residual hydraulic effort to press the clutch pedal down and with luck dislodge the frozen slave cylinder. 2: Get a decent pair of circlip pliers with right angle fingers to remove the circlip. Do not waste your time with inferior equipment. You will find it even more stressful than owning an Alfa 33!  _________________ Alfa 33 1.7 QF I think maybe now I m not so sure |
