cheap tyre fitters
PostPosted: Wed Mar 14, 2007 4:23 pm    Post subject: cheap tyre fitters Reply with quote
does anyone know of any cheap tyres fitters in the Brighton or Crawley area. I was quoted £5 per tyre (fitting balancing and disposal) a while ago but now when i need to get my tyres replaced the cheapest place is £10 per tyre.
Getting goodyear eagle F1 gs-ds3 £36 per tyre from http://ssl.delti.com/cgi-bin/reifenbestellen.pl?typ=D39104&dsco=10
Otherwise ill get them from leathal alloys £47 supplied and fitted Sad £6 more expensive per tyre
PostPosted: Wed Mar 14, 2007 5:58 pm    Post subject: Reply with quote
No tyre fitting centres are going to willingly fit discount 'internet' tyres for you. Lets face it, it's like taking your own tinnies into the boozer.
They will usually either say no, or quote some silly fitting charge.
PostPosted: Thu Mar 15, 2007 1:16 pm    Post subject: Reply with quote
Leathal Alloys do the tyres for £36, same as my tyres and charge £10 per tyre for fitting them. I guess the average price per tyres for fitting is £15, was just hoping to find somewhere that was a bit cheaper.
andys33horley
PostPosted: Thu Mar 15, 2007 3:20 pm    Post subject: Reply with quote
ive just txt a mate of mine finding out price for you
just brought my first 33 16v
PostPosted: Thu Mar 15, 2007 10:29 pm    Post subject: Reply with quote
Thanks, do you by chance know of a guy with a 16v red with gold alloys?? I saw him the other day at the shell garrage??? Or would that be you??
andys33horley
PostPosted: Fri Mar 16, 2007 1:32 pm    Post subject: Reply with quote
no mne has tsw evo wheels mate wasnt me i think the car ur on about is a 8v 33
PostPosted: Sat Mar 17, 2007 10:58 am    Post subject: Reply with quote
possibly, was deffo the later shape, i didnt catch the reg, but if it was G, H reg it was in good shape. Any reply from your budy??
andys33horley
PostPosted: Sun Mar 18, 2007 9:10 pm    Post subject: Reply with quote
no mate sorry just herd from him hes being watched from his boss
ray
PostPosted: Sun Mar 18, 2007 11:08 pm    Post subject: Reply with quote
Hi, the 33 with gold wheels is an 8v. It is a friend's car, he was having some work done by me and a mate.
PostPosted: Tue Mar 20, 2007 11:17 pm    Post subject: Reply with quote
thanks andys33horley
Got my tryes fitted on saturday by Leathal alloys, couldnt risk the wait as my others were bald to the metal Embarassed
First impressions, not impressed, i had theses wheels on my old red 33 (tsw evos from 155 narrow body) with 195 50 15 on them and im sure it handled better. Now i get tyre roll and understeer Sad Gona get tracking done tomorrow, afta iv fitted a new track rod end.
Hey ray, yr mates car looks quite nice, well have to hook up and have a race Smile
PostPosted: Wed Mar 21, 2007 10:12 am    Post subject: Reply with quote
First, give them a chance to wear in - eagle F1s should be good. Maybe up the tyre pressures to stop roll and get that tracking sorted as it will make a big difference if out. Will hold that spark plug spanner for you.
andys33horley
PostPosted: Wed Mar 21, 2007 1:48 pm    Post subject: Reply with quote
if ur intreasted big al im taking my 33 to crawley cruise on 21st april if u wanna meet up get a few 33s togeather as i take mine last time me and my mate went in both our red 33s
PostPosted: Fri Mar 23, 2007 3:40 am    Post subject: Reply with quote
Thanks Paul, I knew about letting tyres bed in, scrub off, 1st heat up cycle, im glad i did as i took it realy slow on the first corner and it felt like i was driving on a wet greasy road.
I have checked tyre pressure, 1 rear was low, all at 30 psi now, i like it high for acceleration, only improvement is no bump steer and no teeth chatter on bumpy roads. Im still getting tyre roll/understeer.
I didnt get my tracking done as i didnt get my car to the garrage on time. When i changed the track rod end, i also ended up changing the strut pan, as it was rusty and holy, had to replace the strutpan bearing aswel, as it fell apart due to being cracked, lucky i had a spare 1 lying around.
Also tightened up a loose rear shock (nut under rear axle), removed all spacers and checked for correct spiggots and clearance. I noticed that the rear drums are a little loose, so i will do them next weekend and adjust the handbrake aswel.
Tracking being done saturday morning, we shal see
Andy, sounds good to me, iv set a reminder im my phone
PostPosted: Sat Mar 24, 2007 10:56 am    Post subject: Reply with quote
ok, so tracking was toeing out by 1 degree, set it up toing in by 30 mins, with all fluids in car and no weights on seats, rear is toing out by 20 mins. Steering wheel now needs to be adjusted, still waiting for pics of the home made steering wheel puller from one of our other members Laughing
Will let you know if its any better
PostPosted: Mon Apr 30, 2007 2:40 pm    Post subject: Reply with quote
Well no better, I upped the tyre pressure on the fronts to 32 and got a mate of mine to test drive my car. He concurs and says the turn is weird.
The car turns in initially and the tyre wall rolls, then once that has settled you then have to turn again. This doesn’t inspire confidence when turning into a fast corner.
I had 205 45 16 et35 on Nexen N3000 tyres on Momo arrows off a Punto GT with 5 mm spacers.
I will try 195 45 15 next and if this doesn’t help I will put my 16” back on with 195 45 16
Have a look at
http://www.carbibles.com/tyre_bible.html
for a good read
Reading that makes me think i should have tracking set to toeing out slightly and that 195 45 15/16's might not be a good idea?? What do you think
http://www.partsemporium.co.uk/tyre%20size%20calculator.htm
PostPosted: Mon Apr 30, 2007 10:47 pm    Post subject: Reply with quote
You want toe out between 2 and 4mm (not 0). More will heat your tires up quickly and give better turn in, (I think racers use up to 7mm?) but will wear your tires out quick. Very Happy
andys33horley
PostPosted: Mon Apr 30, 2007 11:01 pm    Post subject: Reply with quote
hi al i have 195/55/15 on mine it drives lovely
PostPosted: Tue May 01, 2007 1:44 am    Post subject: Reply with quote
andy
55!! how do you drive? I would say meet up and try each others car out, but after blowing me out at the cruise Twisted Evil . If your about tomorrow night il be around Halfords about 20:30, but i wont hold my breath Laughing
Paul
I thought that toeing inwards would give better grip, coz toeing out in the wet i got no grip and serious understeer.
I understand that front wheel drive cars pull with the front wheels and when accelerating the front will lift up and therefore start to toe in slightly.
I was advised to set toe to 0 on a lowered uprated springs/shocks setup, so that when driving it would start to toe in slightly.
After all this there is still the tyre roll Crying or Very sad
andys33horley
PostPosted: Tue May 01, 2007 3:23 pm    Post subject: Reply with quote
not blowing u out but ive got a meeting could do tonite if u want
