Viscous Coupling 60572375 - Anybody got a Scrap One?
tempra2
PostPosted: Fri Mar 23, 2007 12:40 pm    Post subject: Viscous Coupling 60572375 - Anybody got a Scrap One? Reply with quote
Trying to find an alternative part for 60572375 from another Steyr Puch system isn't going particulary well (See my other post) so I'd like to investigate getting one machined up - initial thoughts are perhaps aluminium, or nylon or Delrin or maybe a nice piece of Leerdamer unless anyone has any other suggestions.
Considered getting a batch moulded using a similar material to the original to prevent unwanted vibrations, however this isn't looking feasable.
BUT, I need one to create an engineering drawing: does anybody have a scrap example I can have, or a good one I can buy Question Wink
tvatavuk
PostPosted: Fri Mar 23, 2007 9:12 pm    Post subject: Reply with quote
Exact replica made out of solid material wont be good because of 2 reasons.
1. Rubber one streches a bit when mounting.
2. Chasis mounts usualy unweld from chasis or even crack chasis with rubber mounted, imagine what would happen if you would to use solid mount.
Tino Vatavuk
tempra2
PostPosted: Fri Mar 23, 2007 10:14 pm    Post subject: Reply with quote
H Tino.
Mmmm Ok, thanks for the real world feedback and the PM, certainly food for thought and I'm not in any way dismissing what you are saying.
I understand the chassis mounts (And the chassis) aren't robust, however intuitively I'm feeling that the mount just holds a bearing, therefore no/little force can be transmitted through it. Therefore I'm thinking the original choice of material was chosen with a vibration damping perspective high on the agenda.
Can you think of any material thet will lend itself to machining that would have the properties that we are after?
PostPosted: Fri Mar 23, 2007 10:38 pm    Post subject: Reply with quote
The viscous coupling needs to move around a fair amount and have a fairly strong mount as it is trying to move and twist as it tries to lock the front and rear wheels to the same speed (and when cornering they certainly go at different speeds).
stedee
PostPosted: Sat Mar 24, 2007 3:15 am    Post subject: Reply with quote
you definitely need some kind of rubber or similar mounting in there somewhere otherwise youre viscous coupling will not be attached to the floor for very long,
there are going to be forces there because the vc is basically a clutch so there will be differences in torque causing forces to be transmitted to the mountings.
brum brum
tempra2
PostPosted: Sat Mar 24, 2007 1:45 pm    Post subject: Reply with quote
I really need to get one in my hands to have a good look I think - has anybody in the UK got a dead one?
PostPosted: Sat Mar 24, 2007 7:21 pm    Post subject: Reply with quote
I've got a good one with knackered mounts somewhere.
tempra2
PostPosted: Sun Mar 25, 2007 12:55 pm    Post subject: Reply with quote
Hi Paul
PM'd you
PostPosted: Sun Mar 25, 2007 2:28 pm    Post subject: Reply with quote
I have one floating around (still with the prop shaft) and some dead mounts. I am just outside Stafford if that is easier.
mt
PostPosted: Mon Mar 26, 2007 11:34 am    Post subject: Reply with quote
And i've got a good one with one knackered mount you can borrow, south coast Hants
tempra2
PostPosted: Mon Mar 26, 2007 3:22 pm    Post subject: Reply with quote
Thanks all - Paul has very kindly agreed to send me his dead one so I can have a look at it.
