baldy Alfasud
Posted: Wed Nov 01, 2006 10:56 am Post subject: 16v carb info wanted |
Hi, I know that this has probably been covered before, but has anyone done this conversion on a sprint 16v or 33 road car?
What I need to know for sure is what size jets etc for the twin 40 idf weber carbs from 8v 1.7 engine, ive put on a standard 137 16vengine , chokes are 36. ticks over ok, it sounds glorious. Would be greatly apppreaciated if someone could let me know, ive tried the maintenance section but i thought one of you lot must have done this for fast road or even racing.. Cheers lee  |
markgp4 Alfa Sprint
Posted: Wed Nov 01, 2006 1:26 pm Post subject: |
hi, i cant help with the info you need but you could try asking here.
as if it can be done i am sure one of these lot will know how or when or what time it is!
Good luck chap.
http://www.arcaforum.com/ _________________ make it go faster  |
Serpent33 Alfa Sprint
Posted: Fri Nov 17, 2006 8:33 pm Post subject: |
I'm using 155-160 main jets with choke size like that
Now running 155 main and 175 air corrector _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
Rees Cees Alfasud
Posted: Sun Nov 19, 2006 12:24 am Post subject: |
is this what you are looking for? |
Posted: Sun Nov 19, 2006 10:27 am Post subject: |
what carb config is this engine running on? _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
Rees Cees Alfasud
Posted: Sun Nov 19, 2006 10:32 am Post subject: |
| Serpent33 wrote: |
| what carb config is this engine running on? |
it is running on 40mm Dellorto's whit 32 venturies |
Edward Alfa 33
Posted: Mon Dec 11, 2006 3:19 pm Post subject: |
Hi guys,
Any idea on power for this set up as it looks soooo much easier that after market engine management? I may be worth giving up a few bhp for the simplicity of carbs - but I don't want to loose too much in the process.
Any power and torque figures would be good.
Edward. _________________ The faster the better. |
KitCarLasse Alfa Arna
Joined: 06 Mar 2006 Posts: 24 Location: Copenhagen, Denmark
Posted: Mon Apr 09, 2007 1:58 pm Post subject: 16v karb manifols for sale |
Hi im a guy from Denmark wich builds kitcar's on the VW type 1 chassis and uses Alfa Romeo boxer engines....the adapters for the vw transaxel to fit the alfa boxer is a part we ourself produce.....
Last year building my kitcar we ran into a problem - all racers used them but had never been produced in series prof... Intake manifol's for the 1,7 16v engine to adapt weber / dellorto 40mm karburators !!!!!!
I have seen many pour intake manifols wich we could call homemade
So my buddy Rolf and I desided to manifactor aset of super smooth super flow manifols - bolt on easy - made in one piece alu......
The price for a set of two manifol's are 3300 DK kr or about 472 euro !
Get more info write to me : kitcarlasse@yahoo.dk or +45 23 310 310
3D picture from the cnc-machine is possible to mail to you !
for more info contact me at kitcarlasse@yahoo.dk _________________ Plastic is fantastic ! |
