Posted: Wed Sep 26, 2007 11:24 am Post subject: Wanted Hazard flasher unit |
Anyone got a spare hazard flasher unit that works.
Black, 8 pin- 60581475, B883, 79158, 12v/2(4)x21w, made in italy
Posted: Wed Sep 26, 2007 11:16 pm Post subject: |
John, Are you any good with a soldering iron?
I read your post and it sounds very similar to the problem i had when i first got my car. Take the plastic cover off the relay- you need to push the tabs in at the side of the cover- Then from memory there are 3 solder joints at one end on the printed circuit board, one of them will be dry jointed ( you'll see a faint line around the solder ring on the PCB) Just give it a quick dab with a fully hot iron and that will hopefully do the trick. Mines been ok since then..........bugger, shouldn't have said that.
Lee
Posted: Wed Sep 26, 2007 11:17 pm Post subject: |
| Oh, by the way, didn't post on the other thread as i thought you had sorted it out! |
Posted: Thu Sep 27, 2007 8:09 am Post subject: |
Thanks Lee, i'll have a go at it.
I think replacement can only be a genuine item, not sure if AR still do 'em, but EPR says about £17 i think.
Called in on my local (very good) factors, and we had a good delve into parts books etc, and they showed nothing with 8 pins. Some BMW items went up to 7 pin.
Posted: Sun Sep 30, 2007 12:57 pm Post subject: |
Sorted.
Did as Lee said- it works! - thanks Lee
Posted: Sun Sep 30, 2007 8:37 pm Post subject: |
Glad to be of assistance John. It's not often I can!!
Al....Be VERY careful with that soldering iron around your danglies  |
Posted: Mon Oct 01, 2007 2:59 am Post subject: |
lol Lee
I just went mad and moistened up as many joints as I could, adding a little solder along the way.
Guess what, it seems to work both lying down and erect.
Thanks Lee _________________ x2 33 16v
Posted: Mon Oct 01, 2007 5:33 pm Post subject: |
Nice one Al
Anyone else with relay problems just get in touch! It's the only thing I'm good at apparently  |
Posted: Sun Aug 11, 2013 2:27 pm Post subject: |
Sorry to dig up old threads but I'm going to have to give this a go. It's driving me nuts fiddling with it to make it work.
Can't find a new one anywhere. Can't find the soldering iron either.  _________________ Alfa33 QO 1984
Alfa33 1.3i.e. 1994 |
Posted: Tue Aug 13, 2013 3:37 pm Post subject: |
I forgot to post when I started having problems again about a month ago.
So all in all, it lasts a while
At first I thought it was a wiring problem and remembered what I did last time. I did it again and all is ok again for another 5 years maybe  _________________ x2 33 16v
Posted: Tue Aug 13, 2013 4:24 pm Post subject: |
Nearly 6 years on (OMG!) and mine's still going strong- famous last words... _________________ If it aint broke, fiddle with it until it is!
Posted: Tue Aug 13, 2013 5:21 pm Post subject: |
| 10 years on for me..... |
Posted: Tue Aug 13, 2013 7:19 pm Post subject: |
I can smell smoke............  _________________ PHAT 33 |
Posted: Tue Aug 13, 2013 8:47 pm Post subject: |
Dodgy electrics 'r' us  |
