rsfruitbat Alfa Sprint
Posted: Fri Nov 09, 2007 8:37 am Post subject: 16V 33 exhaust manifold |
Anyone got a half decent secondhand one for sale in the worcestershire area?
Might be able swap / sell / part/x / do a deal on a large bore manifold for same engine that I've got.
rsfruitbat  |
Posted: Sat Nov 10, 2007 2:42 pm Post subject: Re: 16V 33 exhaust manifold |
rsfruitbat wrote: |
rsfruitbat  |
Hi whats the manifold you've get chap?
as mite be intereted
Posted: Mon Nov 12, 2007 2:30 pm Post subject: |
The manifold that may to big for me uses 16V exhaust flanges and about 25mm of std size pipe and then goes to 47mm od pipe before the bend on all primaries. Where the individual pipes from each cylinder join into two pipes this diameter is about 58mm od. the single pipe outlet for main exhaust is about 65mm od. Pipe routing is as per std. Also looks like it would fit on a Sud.
I am building a 1400 for rallying and Im not sure if this would be too big so hence the need maybe for a std size pipe to compare it with.
If I do decide to sell it would probably be early next year.
rsfruitbat |
richard33 Alfasud
Posted: Sat Nov 24, 2007 12:03 am Post subject: |
I'm pretty sure that I've got a newish standard 16v manifold - up at a farm I use to store stuff. I'll try to get there in the next few days and if it's there, you can have it for nowt (as they say upnorf) - assuming you can come and collect it from here - close to J22 of M5. |
Posted: Mon Dec 03, 2007 6:28 pm Post subject: |
That would be great but doont break your back getting up there.
Regards rsfruitbat  |
