irs buggy Alfa Arna
Posted: Thu Apr 03, 2008 8:05 pm Post subject: carbs on 16v.which dizzy? |
hope this question is clear...building a beetle chassised buggy with beetlegearbox and 16v quad cam.gearbox and adaptorplate im thinking of buying may be using adapted beetle or 8valve alfa flywheel,so wont have the extra bit which the sensor thing pickups from...question is...if i use carbs on engine(insteadof injection) will existing dizzy work ok?if not,can i use the 8 valve one??? ps.hope im not offending the purists out there...i love alfas[especially the engines) but with a beetle chassis with porsche rear suspension/brakes and minimal fibreglass body i hope to have the best of all worlds |
rsfruitbat Alfa Sprint
Posted: Fri Apr 04, 2008 7:40 am Post subject: |
I think the 8V dizzy would work as It should just bejsut the same as a non injected car. Dizzy wont know if its an 8V oor 16V. Not sure about fuel injected cars as I dont know if the ECU tells the diazzy when to fire or does any modification to when the firing occurs.
If you are going to use nothing electrical i.e. no ECU, no fuel injection, I suggest you go for the simplest setup.
Regards rsfruitbat |
Posted: Fri Apr 04, 2008 10:32 am Post subject: |
16V dizzy is just a dizzy, no advance / retard mechanism built in so not really suitable.
An 8V dizzy might well work (probably will), but might not quite have the best advance curve for the higher revving 16V engine.
Posted: Fri Apr 04, 2008 7:24 pm Post subject: |
Yep 8V dizzy will work, we been using it in the RWD Corsa project, along with a Jetronic system from a 205GTi Pug
zp
hugh jinjin Alfasud
Posted: Fri Apr 04, 2008 8:13 pm Post subject: |
hi, I have an adaptor plate for a v/w gearbox if you're interested. It's a bit hand knitted but does work! I've also got a dizzy that would do you and a nice pair of 45 dellortos that would be perfect for a 16v. |
baldy Alfasud
irs buggy Alfa Arna
Posted: Sun Apr 06, 2008 10:31 am Post subject: questions...... |
hugh ji jin...how much you after for adaptor plate ,etc(do you have the input shaft for gearbox ?)
baldy....does that ecu kit come as parts that have to be soldered together?? how much does the the whole lot cost?how did you make your manifolds?halves of injection manifolds and carb manifolds welded together??....a mate laser cut plates that fit onto 16v heads and similiar to fit onto bottoms of carbs that now need some bits of pipe (or something..)welded between the plates....my only concerns with this are poor matching=poor airflow,where pipes weld onto unusual shaped holes in plates that bolt onto heads...also no water heated facility on manifolds...what are your thoughts????? |
baldy Alfasud
hugh jinjin Alfasud
Posted: Sun Apr 06, 2008 11:12 pm Post subject: |
just had a re-think, the adaptor is for a hewland mk8/9 ie upside down beetle! so might not be any good unless the bolts are in the same place. I'll have a look at it tomorrow. |
hugh jinjin Alfasud
Posted: Wed Apr 09, 2008 3:53 pm Post subject: |
measured the adaptor today, its not symetrical so your box wouldn't fit unless you flipped it upside down! I'm looking for 220 for the carbs, they're very good condition, only ever been on a race car. I'll give you a pair of 8v carb manifolds to chop up to give you a flange to weld to the top of the 16v throttle bodies as well. if you want the carbs you can have the dizzy for nothing if not then a tenner plus postage? I'll give you the ignition amp as well and whatever bits of the loom it needs. |
