gtvnut Alfa Arna
Posted: Mon May 05, 2008 1:19 am Post subject: Electric Window fault |
My passenger side electric window is dead, drivers side works fine......Could it be a faulty switch?
Fuses look ok.......  |
Posted: Mon May 05, 2008 4:12 am Post subject: |
or a faulty relay/fuse on relay, they are near the steering column on a 16v and are sided, to test swap them over. _________________ x2 33 16v
gtvnut Alfa Arna
Posted: Mon May 05, 2008 5:35 am Post subject: |
| Mine's a series 2... |
Midi Alfa Arna
Posted: Mon May 05, 2008 1:10 pm Post subject: |
I had the same problem. I took off the door upholstery and then tried to detach the window elevator but gave up because couldn't get the upper calble off. Then just put everything back together and now it works! Looks like there was just some contact problem at the wires connector. _________________ Fiat 126A
Lancia Y10 -88 & -89
Lancia Prisma 1.6i.e -89
Lancia Thema 2.0i.e 16v autom.
Alfa Romeo 33 4x4 Giardinetta -89
Alfa Romeo 75 2.0TS -89 |
Posted: Mon May 05, 2008 8:13 pm Post subject: |
my passenger side window somtimes sticks when fully open , I give the switch a toggle and it works fine after about six or seven switches, Paul Hide recently swapped the motor out on one of his cars , it takes a few hours to do but give him a pm Im sure he would explain the process if the motor is dead. _________________ PHAT 33 |
Posted: Mon May 05, 2008 9:15 pm Post subject: |
Simply swap the switches and if the other window no longer works you know it is the switch. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
