Posted: Mon May 19, 2008 3:49 pm Post subject: Brake Servo |
Where the hell does the brake servo vacuum pipe connect to on the non-servo end (on a 16v)?
I'm really confused!  _________________ Fiat Bravo 165 Sport |
Posted: Mon May 19, 2008 4:17 pm Post subject: |
Hope this piccy helps
I disconnect at the servo and pull it thru the bulkhead.
Posted: Mon May 19, 2008 4:40 pm Post subject: |
Thanks John... no idea though. Perhaps some words would help me?!
I is fik? _________________ Fiat Bravo 165 Sport |
Posted: Mon May 19, 2008 7:45 pm Post subject: |
Ok, just had a look under the bonnet.
The plastic tube goes to that big plastic valve looking thing which then joins the ns throttle body at it's rearmost directly under the throttle linkage assembly spring.
Hope that helps a bit more.
I've never disconnected this, and even left it hooked up to the throttle body when i took off the ns head, so not sure how it actually fits to throttle body.
Posted: Tue May 20, 2008 8:18 am Post subject: |
Thanks mate.... that's exactly what I was after!
The engine was running nicely even with this off!  _________________ Fiat Bravo 165 Sport |
