Leaking 16v head cover
bobbber
PostPosted: Wed Jun 04, 2008 1:37 pm    Post subject: Leaking 16v head cover Reply with quote
What next? Rolling Eyes
Well, go under the P4 this morning and find out the head cover gasket is leaking oil at one of the bottom corners. So I think "I'll slightly tighten the bolts there and see if it stops" only to find the thread seems to have given up the ghost there! Surprised
What do I do now? Can I use some of that paint stuff (can't remember what it is) to stop it leaking for a while? Anyone think I can cut a slightly larger thread in this and get away with it?
HELP! Laughing
Bob
Fiat Bravo 165 Sport
bobbber
PostPosted: Wed Jun 04, 2008 1:51 pm    Post subject: Reply with quote
Perhaps loctite a stud in there instead and put a nut on the end... I'm *thinking*!
PostPosted: Wed Jun 04, 2008 2:27 pm    Post subject: Reply with quote
Argh!! Nightmare.
did you fit new gaskets?
Don't know what the paint stuff you mention is.
If you can get the tools in i'd be tempted to try and run a tap (or die- the male one) into the existing thread of the correct size to hopefully reclaim it.
failing that possibly try tapping next size up with care if bolt will clear hole in cover etc etc.
Dunno if the loctite stud idea'll work- might not take because of the oil.
For stud fixing there is a brilliant 'bodgers dream' paste called 'Chemical metal' it is very strong, but again may not take.
Good luck
PostPosted: Wed Jun 04, 2008 2:37 pm    Post subject: Reply with quote
I would have thought it will take the next size tap/die as there's enough 'meat' around it. You'll probably have to drill the cover to take the bolt though. And then you have all the access problems!!
Re what John said, unless you get the hole surgically clean the locktite/chemical metal wont hold.
Our cars are testing our patience at the moment then Bob?!!
bobbber
PostPosted: Wed Jun 04, 2008 2:58 pm    Post subject: Reply with quote
Lee, Yes, you and me both tested here mate! Laughing
John, it was new gasket yes, and hylomar in there too. I think it's failed simply because the thread is broken Crying or Very sad
baldy
PostPosted: Wed Jun 04, 2008 4:54 pm    Post subject: Reply with quote
The stud idea and locktight with a nut should work if you clean the area well. if not you should really get a helicoil fitted to replace the damaged thread.good luck
