Exhaust heat shields
JeremyC
PostPosted: Sun Sep 14, 2008 10:19 pm    Post subject: Exhaust heat shields Reply with quote
The good news is I think the cat on our car is OK.
The noise was the heatshields round the exhaust.
The heatshield around the 2 into 1 was barely attached at either end and full of gravel so I've removed it.
The one round the s bend just after the cat is still attached but it is nearly split through bby one of the attachment points and doesn't really fit as the rear section is a stainless replacement and, I suspect, slightly different.
So...
How essential are those heatshields, do many people still have them present?
Do any new systems come with them fitted?
Your thoughts would be much appreciated.
'93 Black 33 1.7 16v
PostPosted: Sun Sep 14, 2008 10:49 pm    Post subject: Reply with quote
That’s good to hear, thought it might be as i had the same thing. I asked the same question a while back and the general consensus is to remove them.
PostPosted: Mon Sep 15, 2008 11:09 am    Post subject: Reply with quote
I'm about to chop mine off Shocked I've welded the blighters on a couple of times now and the metal is so thin it keeps on cracking off again. I don't believe the exhaust runs close enough to the body to cause any problems.
PostPosted: Mon Sep 15, 2008 4:55 pm    Post subject: Reply with quote
My front one is held on with 1 jubilee clip, 1 exhaust clamp and a prayer.
No back one on two cats over 7 years.
Don't loose any sleep over it, there's plenty more to worry about Laughing
JeremyC
PostPosted: Mon Sep 15, 2008 5:01 pm    Post subject: Reply with quote
Main worry is the proximity of the fuel tank!
Thanks for your input folks, I think the rear one will be coming off when I'm next under there.
johnboy
PostPosted: Tue Sep 16, 2008 5:51 pm    Post subject: Reply with quote
none on mine,just drive fast for cooling Laughing
WODA WE NEED? MORE POWER!!
1999 freestyle superjet
