Posted: Sun Sep 14, 2008 7:26 pm Post subject: coil values?? |
what are the resistance specifications for our specific coil?
on mine they are
Primary, outer to outer 0.9 on the 200 ohms
Secondary, inner to outer 5.82 on the 20k ohms
my second hand spare reads
Primary, outer to outer 1.3 on the 200 ohms
Secondary, inner to outer 5.27 on the 20k ohms
are mine not good? _________________ x2 33 16v
Posted: Wed Sep 17, 2008 1:54 pm Post subject: |
Anyone know what the readings should be? In a service manual it says check readings are within manufactures tolerances and if not replace but doesn’t say what they are??? _________________ x2 33 16v
Posted: Wed Jan 07, 2009 2:42 am Post subject: |
I went to a Lucas dealer and asked him to look up the bosch part number, but there was no coil listed in his book for a 16V?????
My bosch coil has this part number on the bottom
0 221 122 427, however this is not listed at all in his part book???
I went to halfords and they list a bosch part number of
0 221 122 344, so I went back to the Lucas dealer and they are listed at £27.28+vat
Something doesn’t add up here, has someone just fitted any old coil to mine? Could someone, or all of you, please post up your Bosch only part numbers for your coils and say what its for, 16V, IE, 8v ect, thanks _________________ x2 33 16v
Posted: Fri Jan 09, 2009 12:41 pm Post subject: |
Bosch seem to give up on some part numbers. There are some relays they used to make that they no longer list (unfortunatly could do with some for the Maserati).
Posted: Fri May 01, 2009 10:46 am Post subject: |
another member measured 10 coils for me, not sure from what model though.
"All my coils showed 1.1 ohms on the 200 setting, outer to outer
Inner to outer read, 7.5, 7.0, 7.1, 8.1, 7.9, 14.1, 12.4/11.8, 5.5, 7.7 & 7.7" _________________ x2 33 16v
Posted: Mon May 04, 2009 12:57 pm Post subject: |
Thanks to John and Alex for allowing me to take some measurements from their 16v coils.
I got
Primary 0.9 & 0.9
Secondary 6.4 & 5.74
Also another 16v owner said
"Hi Al - measured coil on a 33 16v with ML4.1 and I think the original coil and the primary winding is .8 Ohms. Could not check secondary as the coil lead is very tight and did not want to break it !! Hope this helps" _________________ x2 33 16v
