Posted: Sun Sep 21, 2008 2:49 pm Post subject: Slave cylinder |
Changed my leaky 7 year old slave cylinder today.
Followed advice (from gritsop??) on Bobbbers site, and can confirm it's very good avice. Biggest tip is to wedge a bit of wood in to keep the fork back i.e the clutch fully depressed equivalent. If the slave is completely shot, you may not be able to do this- but my goodness it helps.
i took off manifold and oil filler tube for acces, and it's still fidly but by turning the circlip anticlockwise a bit in situe managed to get a decent pair of (squeeze to open-recommended for one hand use) circlip pliers in.
Posted: Sun Sep 21, 2008 3:11 pm Post subject: |
Glad you found the site useful!
Some additional good advice (if you're using a used cylinder like it did) is to give it a good rub down with some fine sandpaper..!
Posted: Sun Sep 21, 2008 9:00 pm Post subject: Re: Slave cylinder |
| john 33_16v wrote: |
| Biggest tip is to wedge a bit of wood in to keep the fork back i.e the clutch fully depressed equivalent. If the slave is completely shot, you may not be able to do this- but my goodness it helps. |
Not sure it would be possible on a 33, but on a 75 I used a ratchet strap to operate the clutch arm.
