bvolden Alfa Arna
Joined: 15 May 2003 Posts: 8 Location: Trondheim, Norway
Posted: Thu Jul 24, 2003 5:31 pm Post subject: Low compression |
Measured the compression and it read as follows:
Left side 6 and 9
Right side 12 and 12.
Thought the gasket by the cylinders had blown, but it was fine. What else can i do? The damn thing runs bad and I need your advise!
Sincerly
Bjornar |
Ian M Green Cloverleaf
Posted: Fri Jul 25, 2003 10:39 am Post subject: |
| It could be valves coked up and not seating properly. |
ChrisC Alfa Sprint
Posted: Fri Jul 25, 2003 1:12 pm Post subject: a |
Chuck a little oil in each cylinder and do a compression test again. if results improve, its the piston rings, if they stay the same its the valves.. _________________ Alfa Sprint QV - Gone to a better home and in happier health for it
Posted: Sat Jul 26, 2003 10:35 am Post subject: |
I would try the trick with the oil, but also check the cam timing. It does seem a little convenient that it is fine on one bank but low on both cylinders on the other bank. The car will run with the cam timing a tooth out.
